Remove Azure NetApp Files from the NetApp Console
You can remove an Azure NetApp Files system from the NetApp Console. Removing the Azure NetApp Files system does not delete your Azure NetApp Files account, capacity pools, or volumes. You can add Azure NetApp Files back to the Console at any time.
Steps
Open the Azure NetApp Files system.
At the top right of the page, select the three dots
…then Remove Azure NetApp Files.
In the pop-up dialog, select Remove to confirm you want to remove the system.
