Use NetApp data services with Azure Blob storage
After you discover Azure Blob storage accounts in the NetApp Console, you can use NetApp data services for backup, tiering, and data synchronization.
Use NetApp Backup and Recovery to back up data from your on-premises ONTAP and Cloud Volumes ONTAP systems to Azure Blob storage.
To get started, navigate to the Systems page. Drag and drop an on-premises ONTAP or Cloud Volumes ONTAP system on your Azure Blob Storage system.
Use NetApp Cloud Tiering to tier inactive data from on-premises ONTAP clusters to Azure Blob storage.
To get started, navigate to the Systems page. Drag and drop an on-premises ONTAP system on your Azure Blob Storage system.
Use NetApp Copy and Sync to synchronize data to or from Azure Blob storage accounts.
To get started, navigate to the Systems page. Drag and drop the source system on the target system. Your Azure Blob Storage system can be either the source or target.
You can also select your Azure Blob Storage system then Copy & Sync from the Services panel to synchronize data to or from Azure Blob storage accounts.
