Cloud Volumes ONTAP
Azure
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Cloud Volumes ONTAP storage management
Contributors netapp-manini
The NetApp Console provides simplified and advanced management of Cloud Volumes ONTAP storage.
Caution You must create and delete all disks and aggregates directly from the Console. You should not perform these actions from another management tool. Doing so can impact system stability, hamper the ability to add disks in the future, and potentially generate redundant cloud provider fees.
Storage provisioning
The Console makes storage provisioning for Cloud Volumes ONTAP easy by purchasing disks and managing aggregates for you. You only need to create volumes. You can use an advanced allocation option to provision aggregates yourself, if you want.
Simplified provisioning
Aggregates provide cloud storage to volumes. The Console creates aggregates for you when you launch an instance, and when you provision additional volumes.
When you create a volume, the Console does one of three things:
  • It places the volume on an existing aggregate that has sufficient free space.
  • It places the volume on an existing aggregate by purchasing more disks for that aggregate.
  • It purchases disks for a new aggregate and places the volume on that aggregate.
The Console determines where to place a new volume by looking at several factors: an aggregate's maximum size, whether thin provisioning is enabled, and free space thresholds for aggregates.
Advanced allocation
You can also manage aggregates. From the Advanced allocation page, you can create new aggregates that include a specific number of disks, add disks to an existing aggregate, and create volumes in specific aggregates.
Capacity management
The organization or account admin can configure the Console to notify you of storage capacity decisions or whether to automatically manage capacity requirements for you.
This behavior is determined by the Capacity Management Mode on a Console agent. The Capacity Management Mode affects all Cloud Volumes ONTAP systems managed by that Console agent. If you have another Console agent, it can be configured differently.
Automatic capacity management
The Capacity Management Mode is set to automatic by default. In this mode, the Console checks the free space ratio every 15 minutes to determine if the free space ratio falls below the specified threshold. If more capacity is needed, it initiates purchase of new disks, deletes unused collections of disks (aggregates), moves volumes between aggregates as required, and attempts to prevent disk failure.
The following examples illustrate how this mode works:
  • If an aggregate reaches the capacity threshold and it has room for more disks, the Console automatically purchases new disks for that aggregate so volumes can continue to grow.
  • If an aggregate reaches the capacity threshold and it can't support any additional disks, the Console automatically moves a volume from that aggregate to an aggregate with available capacity or to a new aggregate.
    If the Console creates a new aggregate for the volume, it chooses a disk size that accommodates the size of that volume.
    Note that free space is now available on the original aggregate. Existing volumes or new volumes can use that space. The space can't be returned to the cloud provider in this scenario.
  • If an aggregate contains no volumes for more than 12 hours, the Console deletes it.
Management of LUNs with automatic capacity management
The Console's automatic capacity management doesn't apply to LUNs. When it creates a LUN, it disables the autogrow feature.
Manual capacity management
If the organization or account admin sets the Capacity Management Mode to manual, the Console informs you to take appropriate actions for capacity decisions. The same examples described in the automatic mode apply to the manual mode, but it is up to you to accept the actions.
Related links
