Disks and aggregates used for Cloud Volumes ONTAP clusters
Understanding how Cloud Volumes ONTAP uses cloud storage can help you understand your storage costs.
You must create and delete all disks and aggregates from the NetApp Console. You should not perform these actions from another management tool. Doing so can impact system stability, hamper the ability to add disks in the future, and potentially generate redundant cloud provider fees. |
Overview
Cloud Volumes ONTAP uses cloud provider storage as disks and groups them into one or more aggregates. Aggregates provide storage to one or more volumes.
Several types of cloud disks are supported. You choose the disk type when you create a volume and the default disk size when you deploy Cloud Volumes ONTAP.
The total amount of storage purchased from a cloud provider is the raw capacity. The usable capacity is less because approximately 12 to 14 percent is overhead that is reserved for Cloud Volumes ONTAP use. For example, if the Console creates a 500 GiB aggregate, the usable capacity is 442.94 GiB. |
Azure storage
In Azure, an aggregate can contain up to 12 disks that are all the same size. The disk type and maximum disk size depends on whether you use a single-node system or an HA pair:
- Single-node systems
Single-node systems can use these types of Azure Managed Disks:
Premium SSD Managed Disks provide high performance for I/O-intensive workloads at a higher cost.
Premium SSD v2 Managed Disks provide higher performance with lower latency at a lower cost for both single node and HA pairs, compared to Premium SSD Managed Disks.
Standard SSD Managed Disks provide consistent performance for workloads that require low IOPS.
Standard HDD Managed Disks are a good choice if you don't need high IOPS and want to reduce your costs.
Each managed disk type has a maximum disk size of 32 TiB.
You can pair a managed disk with Azure Blob storage to low-cost object storage.
- HA pairs
HA pairs use two types of disks which provide high performance for I/O-intensive workloads at a higher cost:
Premium page blobs with a maximum disk size of 8 TiB
Managed disks with a maximum disk size of 32 TiB
Related links
RAID type
The RAID type for each Cloud Volumes ONTAP aggregate is RAID0 (striping). Cloud Volumes ONTAP relies on the cloud provider for disk availability and durability. No other RAID types are supported.
Hot spares
RAID0 doesn't support the use of hot spares for redundancy.
Creating unused disks (hot spares) attached to a Cloud Volumes ONTAP instance is an unnecessary expense and may prevent provisioning additional space as needed. Therefore, it's not recommended.
