Cloud Volumes ONTAP
Azure
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Supported ONTAP versions for Cloud Volumes ONTAP deployments
Contributors netapp-manini
The NetApp Console enables you to choose from several different ONTAP versions when you add a Cloud Volumes ONTAP system.
Cloud Volumes ONTAP versions other than those listed here are not available for new deployments. For information on upgrade, refer to Supported upgrade paths.
Azure
Single node
  • 9.17.1 RC1
  • 9.16.1 P3
  • 9.15.1 P10
  • 9.14.1 P13
  • 9.13.1 P16
  • 9.12.1 P18
HA pair
  • 9.17.1 RC1
  • 9.16.1 P3
  • 9.15.1 P10
  • 9.14.1 P13
  • 9.13.1 P16
  • 9.12.1 P18
