Cloud Volumes ONTAP
Azure
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Set up storage VM disaster recovery for Cloud Volumes ONTAP
Contributors netapp-manini
The NetApp Console does not offer setup or orchestration support for storage VM (SVM) disaster recovery. To perform these tasks, use ONTAP System Manager or the ONTAP CLI.
If you set up SnapMirror SVM replication between two Cloud Volumes ONTAP systems, the replication must be between two HA pair systems or two single node systems. You can't set up SnapMirror SVM replication between an HA pair and a single node system.
Refer to the following documents for the ONTAP CLI instructions.
