Cloud Volumes ONTAP
Azure
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Remove a Cloud Volumes ONTAP system from NetApp Console
Contributors Noah-Hardy netapp-manini
You can remove a Cloud Volumes ONTAP system to move it to another system or to troubleshoot discovery issues.
About this task
Removing a Cloud Volumes ONTAP system removes it from the NetApp Console. It does not delete the Cloud Volumes ONTAP system. You can later rediscover the system if you need.
Steps
  1. On the Systems page, double-click on the system you want to remove.
  2. On the upper right of the Console, click the An icon that shows three horizontal dots for additional actions icon, and select Remove from workspace.
  3. In the Remove from workspace window, click Remove.
Result
The Console removes the system. Users can rediscover the deleted system from the Systems page at any time.
