Cloud Volumes ONTAP
Azure marketplace image verification for Cloud Volumes ONTAP
Contributors netapp-manini
Azure image verification complies with enhanced NetApp security requirements. Verifying an image file is a straightforward process. However, the Azure image signature verification requires specific considerations for the Azure VHD image file because it is altered in the Azure marketplace.
Note Azure image verification is supported on Cloud Volumes ONTAP 9.15.0 and later.
Azure's alteration of published VHD files
