Cloud Volumes ONTAP
Learn about Cloud Volumes ONTAP deployment options in Azure
Contributors netapp-manini netapp-ahibbard
NetApp provides two options for deploying Cloud Volumes ONTAP on Azure. Cloud Volumes ONTAP traditionally relies on the NetApp Console for deployment and orchestration. Beginning with Cloud Volumes ONTAP 9.16.1, you can take advantage of Azure marketplace direct deployment, a streamlined process that provides access to a limited, but still powerful set of Cloud Volumes ONTAP features and options.
When you deploy Cloud Volumes ONTAP directly from the Azure marketplace, you're not required to set up the Console agent or meet other security and onboarding criteria required for deploying Cloud Volumes ONTAP through the Console. From the Azure marketplace, you can quickly deploy Cloud Volumes ONTAP in a few clicks and explore its core features and capabilities in your environment.
On completing the deployment in the Azure marketplace, you can discover these systems in the Console. After discovery, you can manage them as Cloud Volumes ONTAP systems and take advantage of all the Console capabilities. Refer to Discover the deployed systems in the Console.
Here is the feature comparison between the two options. Note that the features of a standalone instance deployed through the Azure marketplace change when it is discovered in the Console.
Azure marketplace NetApp Console
Onboarding
Shorter and easier, minimal preparation required for direct deployment
Longer onboarding process, including the installation of the Console agent
Supported virtual machine (VM) types
Eds_v5 and Ls_v3 instance types
Full range of VM types.
Supported configurations in Azure
License
Free license
Any capacity-based license.
Cloud Volumes ONTAP licensing
NetApp support
Not included
Available, based on the license type
Capacity
Up to 500 GiB
Expandable by configuration
Deployment model
High-availability (HA) mode deployment in single availability zone (AZ)
All supported configurations, including single node and HA modes, single and multiple AZ deployments
Supported disk type
Premium SSD v2 Managed Disks
Wider support.
Supported disk types in Azure
Write speed (fast write mode)
Not supported
Supported, based on your configuration.
Learn about write speeds in Cloud Volumes ONTAP.
Orchestration capabilities
Not available
Available through NetApp Console, based on the license type
Number of supported storage VMs
One per deployment
Multiple storage VMs, based on your configuration.
Supported number of storage VMs
Changing the instance type
Not supported
Supported
FabricPool tiering
Not supported
Supported
Related links
