Cloud Volumes ONTAP
Supported client protocols for Cloud Volumes ONTAP
Contributors netapp-manini
Cloud Volumes ONTAP supports the iSCSI, NFS, SMB, NVMe-TCP, and S3 client protocols.
iSCSI
iSCSI is a block protocol that can run on standard Ethernet networks. Most client operating systems offer a software initiator that runs over a standard Ethernet port.
NFS
NFS is the traditional file access protocol for UNIX and LINUX systems. Clients can access files in ONTAP volumes using the NFSv3, NFSv4, and NFSv4.1 protocols. You can control file access using UNIX-style permissions, NTFS-style permissions, or a mix of both.
Clients can access the same files using both NFS and SMB protocols.
SMB
SMB is the traditional file access protocol for Windows systems. Clients can access files in ONTAP volumes using the SMB 2.0, SMB 2.1, SMB 3.0, and SMB 3.1.1 protocols. Just like with NFS, a mix of permission styles are supported.
S3
Cloud Volumes ONTAP supports S3 as an option for scale-out storage. S3 protocol support enables you to configure S3 client access to objects contained in a bucket in a storage VM (SVM).
NVMe-TCP
Beginning with ONTAP version 9.12.1, NVMe-TCP is supported for all cloud providers. Cloud Volumes ONTAP supports NVMe-TCP as a block protocol for storage VMs (SVMs) during deployment, and installs the required NVMe licenses automatically.
NetApp Console does not provide any management capabilities for NVMe-TCP.
For more information on configuring NVMe through ONTAP, refer to the ONTAP documentation: Configure a storage VM for NVMe.
