Learn about Cloud Volumes ONTAP
Cloud Volumes ONTAP enables you to optimize your cloud storage costs and performance while enhancing data protection, security, and compliance.
Cloud Volumes ONTAP is a software-only storage appliance that runs ONTAP data management software in the cloud. It provides enterprise-grade storage with the following key features:
Storage efficiencies
Leverage built-in data deduplication, data compression, thin provisioning, and cloning to minimize storage costs.
High availability
Ensure enterprise reliability and continuous operations in case of failures in your cloud environment.
Data protection
Cloud Volumes ONTAP leverages SnapMirror, NetApp's industry-leading replication technology, to replicate on-premises data to the cloud so it's easy to have secondary copies available for multiple use cases.
Cloud Volumes ONTAP also integrates with NetApp Backup and Recovery to deliver backup and restore capabilities for protection, and long-term archive of your cloud data.
Data tiering
Switch between high and low-performance storage pools on-demand without taking applications offline.
Application consistency
Ensure consistency of NetApp Snapshot copies using NetApp SnapCenter.
Data security
Cloud Volumes ONTAP supports data encryption and provides protection against viruses and ransomware.
Privacy compliance controls
Integration with NetApp Data Classification helps you understand data context and identify sensitive data.
Licenses for ONTAP features are included with Cloud Volumes ONTAP. |
