Learn about performance monitoring for Cloud Volumes ONTAP workloads
You can review performance results to help you decide which workloads are appropriate for Cloud Volumes ONTAP.
Performance technical reports
Cloud Volumes ONTAP for Google Cloud
CPU performance
Cloud Volumes ONTAP nodes show as highly utilized (over 90%) from your cloud provider's monitoring tools. This is because ONTAP reserves all vCPUs presented to the virtual machine so that they are available when needed.
For information, refer to the NetApp knowledgebase article about how to monitor ONTAP CPU utilization using the CLI
