Cloud Volumes ONTAP
Google Cloud
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Connect to a LUN on Cloud Volumes ONTAP from your host system
Contributors netapp-manini
When you create an iSCSI volume, the NetApp Console automatically creates a LUN for you. We’ve made it simple by creating just one LUN per volume, so there's no management involved. After you create the volume, use the IQN to connect to the LUN from your hosts.
Note the following:
  • The Console's automatic capacity management doesn't apply to LUNs. When it creates a LUN, it disables the autogrow feature.
  • You can create additional LUNs from ONTAP System Manager or the ONTAP CLI.
Steps
  1. From the left navigation menu, select Storage > Management.
  2. On the Systems page, double-click the Cloud Volumes ONTAP system on which you want to manage volumes.
  3. In the system, select the Volumes tab.
  4. Go to the required volume tile and then select Manage volume to access the Manage Volumes panel on the right.
  5. Click Target iQN.
  6. Click Copy to copy the iQN name.
  7. Set up an iSCSI connection from the host to the LUN.
