Cloud Volumes ONTAP
Google Cloud
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Manage Keystone subscriptions for Cloud Volumes ONTAP through NetApp Console
Contributors netapp-manini
Manage your Keystone subscriptions in the NetApp Console by enabling subscriptions for use with Cloud Volumes ONTAP and by requesting changes to the committed capacity for your subscription's service levels. Requesting additional capacity for a service level provides more storage for Cloud Volumes ONTAP systems.
NetApp Keystone is a flexible pay-as-you-grow subscription-based service that delivers a hybrid cloud experience for customers who prefer OpEx to CapEx or leasing.
Required Console role
To perform this task, you need the Licenses and subscriptions admin role.Learn about Licenses and subscriptions roles for NetApp Console.
Authorize your account
Before you can use and manage Keystone subscriptions in the Console, you need to contact NetApp to authorize your Console account with your Keystone subscriptions.
Steps
  1. From the NetApp Console menu, select Administration > Licenses and subscriptions.
  2. Select Keystone Subscriptions.
  3. If you see the Welcome to NetApp Keystone page, send an email to the address listed on the page.
    A NetApp representative will process your request by authorizing your account to access the subscriptions.
  4. Come back to the Keystone Subscriptions tab to view your subscriptions.
After NetApp authorizes your account, you can link Keystone subscriptions for use with Cloud Volumes ONTAP. This action enables users to select the subscription as the charging method for new Cloud Volumes ONTAP systems.
Steps
  3. For the subscription that you want to link, select An icon that is three side-by-side dots and select Link.
Result
The subscription is now linked to your Console organization or account and available to select when creating a Cloud Volumes ONTAP working environment.
Request more or less committed capacity
If you want to change the committed capacity for your subscription's service levels, you can send a request to NetApp directly from the Console. Requesting additional capacity for a service level provides more storage for Cloud Volumes ONTAP systems.
Steps
  3. For the subscription that you want to adjust the capacity, select An icon that is three side-by-side dots and select View detail and edit.
  4. Enter the requested committed capacity for one or more subscriptions.
  5. Scroll down, enter any additional details for the request, and then select Submit.
Result
Your request creates a ticket in NetApp's system for processing.
Monitor usage
The Digital Advisor dashboard enables you to monitor Keystone subscription usage and generate reports.
If you no longer want to use a Keystone subscription with the Console, you can unlink the subscription. Note that you can only unlink a subscription that isn't attached to an existing Cloud Volumes ONTAP subscription.
Steps
  2. Select Keystone.
  3. For the subscription that you want to unlink, select An icon that is three side-by-side dots and select Unlink.
Result
The subscription is unlinked from your Console organization or account and no longer available to select when creating a Cloud Volumes ONTAP working environment.
