Cloud Volumes ONTAP
Set up Azure networking for Cloud Volumes ONTAP
Contributors netapp-manini netapp-ahibbard
The NetApp Console handles the set up of networking components for Cloud Volumes ONTAP, such as IP addresses, netmasks, and routes. You need to make sure that outbound internet access is available, that enough private IP addresses are available, that the right connections are in place, and more.
Requirements for Cloud Volumes ONTAP
The following networking requirements must be met in Azure.
Outbound internet access
Cloud Volumes ONTAP systems require outbound internet access for accessing external endpoints for various functions. Cloud Volumes ONTAP can't operate properly if these endpoints are blocked in environments with strict security requirements.
The Console agent also contacts several endpoints for day-to-day operations. For information about endpoints, refer to View endpoints contacted from the Console agent and Prepare networking for using the Console.
Cloud Volumes ONTAP endpoints
Cloud Volumes ONTAP uses these endpoints to communicate with various services.
Endpoints Applicable for Purpose Deployment modes Impact if unavailable
https://netapp-cloud-account.auth0.com
Authentication
Used for authentication in the Console.
Standard and restricted modes.
User authentication fails and the following services remain unavailable:
  • Cloud Volumes ONTAP services
  • ONTAP services
  • Protocols and proxy services
https://vault.azure.net
Key Vault
Used to retrieve client secret keys from the Azure Key Vault when using customer-managed keys (CMK).
Standard, restricted, and private modes.
Cloud Volumes ONTAP services are unavailable.
https://api.bluexp.netapp.com/tenancy
Tenancy
Used to retrieve the Cloud Volumes ONTAP resources from the Console to authorize resources and users.
Cloud Volumes ONTAP resources and the users are not authorized.
https://mysupport.netapp.com/aods/asupmessage
https://mysupport.netapp.com/asupprod/post/1.0/postAsup
AutoSupport
Used to send AutoSupport telemetry data to NetApp support.
AutoSupport information remains undelivered.
https://management.azure.com
https://login.microsoftonline.com
https://bluexpinfraprod.eastus2.data.azurecr.io
https://core.windows.net
Public regions
Communication with Azure services.
Cloud Volumes ONTAP cannot communicate with Azure service to perform specific operations for the Console in Azure.
https://management.chinacloudapi.cn
https://login.chinacloudapi.cn
https://blob.core.chinacloudapi.cn
https://core.chinacloudapi.cn
China Region
https://management.microsoftazure.de
https://login.microsoftonline.de
https://blob.core.cloudapi.de
https://core.cloudapi.de
Germany Region
https://management.usgovcloudapi.net
https://login.microsoftonline.us
https://blob.core.usgovcloudapi.net
https://core.usgovcloudapi.net
Government regions
https://management.azure.microsoft.scloud
https://login.microsoftonline.microsoft.scloud
https://blob.core.microsoft.scloud
https://core.microsoft.scloud
Government DoD regions
Network proxy configuration of NetApp Console agent
You can use the proxy servers configuration of the NetApp Console agent to enable outbound internet access from Cloud Volumes ONTAP. The Console supports two types of proxies:
  • Explicit proxy: The outbound traffic from Cloud Volumes ONTAP uses the HTTP address of the proxy server specified during the proxy configuration of the Console agent. The administrator might also have configured user credentials and root CA certificates for additional authentication. If a root CA certificate is available for the explicit proxy, make sure to obtain and upload the same certificate to your Cloud Volumes ONTAP system using the ONTAP CLI: security certificate install command.
  • Transparent proxy: The network is configured to automatically route outbound traffic from Cloud Volumes ONTAP through the proxy for the Console agent. When setting up a transparent proxy, the administrator needs to provide only a root CA certificate for connectivity from Cloud Volumes ONTAP, not the HTTP address of the proxy server. Make sure that you obtain and upload the same root CA certificate to your Cloud Volumes ONTAP system using the ONTAP CLI: security certificate install command.
For information about configuring proxy servers, refer to the Configure the Console agent to use a proxy server.
IP addresses
The Console automatically allocates the required number of private IP addresses to Cloud Volumes ONTAP in Azure. You need to make sure that your networking has enough private IP addresses available.
The number of LIFs allocated for Cloud Volumes ONTAP depends on whether you deploy a single-node system or an HA pair. A LIF is an IP address associated with a physical port. An SVM management LIF is required for management tools like SnapCenter.
Note An iSCSI LIF provides client access over the iSCSI protocol and is used by the system for other important networking workflows. These LIFs are required and should not be deleted.
IP addresses for a single-node system
The Console allocates 5 or 6 IP addresses to a single-node system:
  • Cluster management IP
  • Node management IP
  • Intercluster IP for SnapMirror
  • NFS/CIFS IP
  • iSCSI IP
    Note The iSCSI IP provides client access over the iSCSI protocol. It is also used by the system for other important networking workflows. This LIF is required and should not be deleted.
  • SVM management (optional - not configured by default)
IP addresses for HA pairs
The Console allocates IP addresses to 4 NICs (per node) during deployment.
Note that the Console creates an SVM management LIF on HA pairs, but not on single-node systems in Azure.
NIC0
  • Intercluster IP
  • iSCSI IP
NIC1
  • Cluster network IP
NIC2
  • Cluster Interconnect IP (HA IC)
NIC3
  • Pageblob NIC IP (disk access)
Note NIC3 is only applicable to HA deployments that use page blob storage.
The above IP addresses do not migrate on failover events.
Additionally, 4 frontend IPs (FIPs) are configured to migrate on failover events. These frontend IPs live in the load balancer.
  • NodeA data IP (NFS/CIFS)
  • NodeB data IP (NFS/CIFS)
  • SVM management IP
Secure connections to Azure services
By default, the Console enables an Azure Private Link for connections between Cloud Volumes ONTAP and Azure page blob storage accounts.
In most cases, there's nothing that you need to do—the Console manages the Azure Private Link for you. But if you use Azure Private DNS, then you'll need to edit a configuration file. You should also be aware of a requirement for the location of the Console agent in Azure.
You can also disable the Private Link connection, if required by your business needs. If you disable the link, the Console configures Cloud Volumes ONTAP to use a service endpoint instead.
Networking for Azure VNet encryption
Cloud Volumes ONTAP supports Azure Virtual Network (VNet) encryption for encrypting VM-to-VM traffic inside a VNet or across peered VNets. This feature is configured at the Azure VNet layer and is independent of Cloud Volumes ONTAP topology (single node or HA).
You only need to ensure that Accelerated Networking is enabled on the VM's NICs and review Azure VNet encryption requirements and limitations before enabling the feature. You should not modify NetApp managed load balancer objects.
Connections to other ONTAP systems
To replicate data between a Cloud Volumes ONTAP system in Azure and ONTAP systems in other networks, you must have a VPN connection between the Azure VNet and the other network—for example, your corporate network.
Port for the HA interconnect
A Cloud Volumes ONTAP HA pair includes an HA interconnect, which allows each node to continually check whether its partner is functioning and to mirror log data for the other’s nonvolatile memory. The HA interconnect uses TCP port 10006 for communication.
By default, communication between the HA interconnect LIFs is open and there are no security group rules for this port. But if you create a firewall between the HA interconnect LIFs, then you need to ensure that TCP traffic is open for port 10006 so that the HA pair can operate properly.
Only one HA pair in an Azure resource group
You must use a dedicated resource group for each Cloud Volumes ONTAP HA pair that you deploy in Azure. Only one HA pair is supported in a resource group.
The Console experiences connection issues if you try to deploy a second Cloud Volumes ONTAP HA pair in an Azure resource group.
Security group rules
The Console creates Azure security groups that include the inbound and outbound rules for Cloud Volumes ONTAP to operate successfully. View security group rules for the Console agent.
The Azure security groups for Cloud Volumes ONTAP require the appropriate ports to be open for internal communication between the nodes. Learn about ONTAP internal ports.
We do not recommend modifying the predefined security groups or using custom security groups. However, if you must, note that the deployment process requires the Cloud Volumes ONTAP system to have full access within its own subnet. After the deployment is complete, if you decide to modify the network security group, ensure to keep the cluster ports and HA network ports open, because the HA networking relies on unrestricted communication between the two nodes. Also, the IP addresses of the nodes are automatically defined during deployment. This ensures seamless communication within the Cloud Volumes ONTAP cluster (any-to-any communication between the nodes).
Inbound rules for single-node systems
When you add a Cloud Volumes ONTAP system and choose a predefined security group, you can choose to allow traffic within one of the following:
  • Selected VNet only: The source for inbound traffic is the subnet range of the VNet for the Cloud Volumes ONTAP system and the subnet range of the VNet where the Console agent resides. This is the recommended option.
  • All VNets: The source for inbound traffic is the 0.0.0.0/0 IP range.
  • Disabled: This option restricts the public network access to your storage account, and disables data tiering for Cloud Volumes ONTAP systems. This is a recommended option if your private IP addresses should not be exposed even within the same VNet due to security regulations and policies.
Priority and name Port and protocol Source and destination Description
1000
inbound_ssh
22
TCP
Any to Any
SSH access to the IP address of the cluster management LIF or a node management LIF
1001
inbound_http
80
TCP
Any to Any
HTTP access to the ONTAP System Manager web console using the IP address of the cluster management LIF
1002
inbound_111_tcp
111
TCP
Any to Any
Remote procedure call for NFS
1003
inbound_111_udp
111
UDP
Any to Any
1004
inbound_139
139
TCP
Any to Any
NetBIOS service session for CIFS
1005
inbound_161-162 _tcp
161-162
TCP
Any to Any
Simple network management protocol
1006
inbound_161-162 _udp
161-162
UDP
Any to Any
1007
inbound_443
443
TCP
Any to Any
Connectivity with the Console agent and HTTPS access to the ONTAP System Manager web console using the IP address of the cluster management LIF
1008
inbound_445
445
TCP
Any to Any
Microsoft SMB/CIFS over TCP with NetBIOS framing
1009
inbound_635_tcp
635
TCP
Any to Any
NFS mount
1010
inbound_635_udp
635
UDP
Any to Any
NFS mount
1011
inbound_749
749
TCP
Any to Any
Kerberos
1012
inbound_2049_tcp
2049
TCP
Any to Any
NFS server daemon
1013
inbound_2049_udp
2049
UDP
Any to Any
NFS server daemon
1014
inbound_3260
3260
TCP
Any to Any
iSCSI access through the iSCSI data LIF
1015
inbound_4045-4046_tcp
4045-4046
TCP
Any to Any
NFS lock daemon and network status monitor
1016
inbound_4045-4046_udp
4045-4046
UDP
Any to Any
1017
inbound_10000
10000
TCP
Any to Any
Backup using NDMP
1018
inbound_11104-11105
11104-11105
TCP
Any to Any
SnapMirror data transfer
3000
inbound_deny _all_tcp
Any port
TCP
Any to Any
Block all other TCP inbound traffic
3001
inbound_deny _all_udp
Any port
UDP
Any to Any
Block all other UDP inbound traffic
65000
AllowVnetInBound
Any port
Any protocol
VirtualNetwork to VirtualNetwork
Inbound traffic from within the VNet
65001
AllowAzureLoad BalancerInBound
Any port
Any protocol
AzureLoadBalancer to Any
Data traffic from the Azure Standard Load Balancer
65500
DenyAllInBound
Any port
Any protocol
Any to Any
Block all other inbound traffic
Inbound rules for HA systems
Note HA systems have less inbound rules than single-node systems because inbound data traffic goes through the Azure Standard Load Balancer. Because of this, traffic from the Load Balancer should be open, as shown in the "AllowAzureLoadBalancerInBound" rule.
100
inbound_443
443
Any protocol
Any to Any
101
inbound_111_tcp
111
Any protocol
Any to Any
102
inbound_2049_tcp
2049
Any protocol
Any to Any
NFS server daemon
111
inbound_ssh
22
Any protocol
Any to Any
121
inbound_53
53
Any protocol
Any to Any
DNS and CIFS
65000
AllowVnetInBound
Any port
Any protocol
65001
Any port
Any protocol
65500
DenyAllInBound
Any port
Any protocol
Any to Any
Outbound rules
The predefined security group for Cloud Volumes ONTAP opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
Basic outbound rules
The predefined security group for Cloud Volumes ONTAP includes the following outbound rules.
Port Protocol Purpose
All
All TCP
All outbound traffic
All
All UDP
Advanced outbound rules
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by Cloud Volumes ONTAP.
Note The source is the interface (IP address) on the Cloud Volumes ONTAP system.
Service Port Protocol Source Destination Purpose
Active Directory
88
TCP
Node management LIF
Active Directory forest
Kerberos V authentication
137
UDP
Node management LIF
NetBIOS name service
138
UDP
Node management LIF
NetBIOS datagram service
139
TCP
Node management LIF
389
TCP & UDP
Node management LIF
LDAP
445
TCP
Node management LIF
464
TCP
Node management LIF
Kerberos V change & set password (SET_CHANGE)
464
UDP
Node management LIF
Kerberos key administration
749
TCP
Node management LIF
Kerberos V change & set Password (RPCSEC_GSS)
88
TCP
Data LIF (NFS, CIFS, iSCSI)
137
UDP
Data LIF (NFS, CIFS)
138
UDP
139
TCP
389
TCP & UDP
LDAP
445
TCP
464
TCP
464
UDP
749
TCP
Kerberos V change & set password (RPCSEC_GSS)
AutoSupport
HTTPS
443
Node management LIF
AutoSupport (HTTPS is the default)
HTTP
80
Node management LIF
AutoSupport (only if the transport protocol is changed from HTTPS to HTTP)
TCP
3128
Node management LIF
Console agent
Sending AutoSupport messages through a proxy server on the Console agent, if an outbound internet connection isn't available
Configuration backups
HTTP
80
Node management LIF
http://<console-agent-IP-address>/occm/offboxconfig
Send configuration backups to the Console agent. ONTAP documentation.
DHCP
68
UDP
Node management LIF
DHCP
DHCP client for first-time setup
DHCPS
67
UDP
Node management LIF
DHCP
DHCP server
DNS
53
UDP
Node management LIF and data LIF (NFS, CIFS)
DNS
DNS
NDMP
18600–18699
TCP
Node management LIF
Destination servers
NDMP copy
SMTP
25
TCP
Node management LIF
Mail server
SMTP alerts, can be used for AutoSupport
SNMP
161
TCP
Node management LIF
Monitor server
Monitoring by SNMP traps
161
UDP
Node management LIF
Monitor server
162
TCP
Node management LIF
Monitor server
162
UDP
Node management LIF
Monitor server
SnapMirror
11104
TCP
Intercluster LIF
ONTAP intercluster LIFs
Management of intercluster communication sessions for SnapMirror
11105
TCP
Intercluster LIF
Syslog
514
UDP
Node management LIF
Syslog server
Syslog forward messages
Requirements for the Console agent
If you haven't created a Console agent yet, you should review networking requirements for the Console agent as well.
