Cloud Volumes ONTAP
All cloud providers
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
AWS security group inbound and outbound rules for Cloud Volumes ONTAP
Contributors netapp-ahibbard netapp-manini
The NetApp Console creates AWS security groups that include the inbound and outbound rules that Cloud Volumes ONTAP needs to operate successfully. You might want to refer to the ports for testing purposes or if you prefer to use your own security groups.
Rules for Cloud Volumes ONTAP
The security group for Cloud Volumes ONTAP requires both inbound and outbound rules.
Inbound rules
When you add a Cloud Volumes ONTAP system and choose a predefined security group, you can choose to allow traffic within one of the following:
  • Selected VPC only: the source for inbound traffic is the subnet range of the VPC for the Cloud Volumes ONTAP system and the subnet range of the VPC where the Console agent resides. This is the recommended option.
  • All VPCs: the source for inbound traffic is the 0.0.0.0/0 IP range.
Protocol Port Purpose
All ICMP
All
Pinging the instance
HTTP
80
HTTP access to the ONTAP System Manager web console using the IP address of the cluster management LIF
HTTPS
443
Connectivity with the Console agent and HTTPS access to the ONTAP System Manager web console using the IP address of the cluster management LIF
SSH
22
SSH access to the IP address of the cluster management LIF or a node management LIF
TCP
111
Remote procedure call for NFS
TCP
139
NetBIOS service session for CIFS
TCP
161-162
Simple network management protocol
TCP
445
Microsoft SMB/CIFS over TCP with NetBIOS framing
TCP
635
NFS mount
TCP
749
Kerberos
TCP
2049
NFS server daemon
TCP
3260
iSCSI access through the iSCSI data LIF
TCP
4045
NFS lock daemon
TCP
4046
Network status monitor for NFS
TCP
10000
Backup using NDMP
TCP
11104
Management of intercluster communication sessions for SnapMirror
TCP
11105
SnapMirror data transfer using intercluster LIFs
UDP
111
UDP
161-162
UDP
635
NFS mount
UDP
2049
NFS server daemon
UDP
4045
NFS lock daemon
UDP
4046
UDP
4049
NFS rquotad protocol
Outbound rules
The predefined security group for Cloud Volumes ONTAP opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
Basic outbound rules
The predefined security group for Cloud Volumes ONTAP includes the following outbound rules.
All ICMP
All
All outbound traffic
All TCP
All
All UDP
All
Advanced outbound rules
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by Cloud Volumes ONTAP.
Note The source is the interface (IP address) on the Cloud Volumes ONTAP system.
Service Protocol Port Source Destination Purpose
Active Directory
TCP
88
Node management LIF
Active Directory forest
Kerberos V authentication
UDP
137
Node management LIF
NetBIOS name service
UDP
138
Node management LIF
NetBIOS datagram service
TCP
139
Node management LIF
TCP & UDP
389
Node management LIF
LDAP
TCP
445
Node management LIF
TCP
464
Node management LIF
Kerberos V change & set password (SET_CHANGE)
UDP
464
Node management LIF
Kerberos key administration
TCP
749
Node management LIF
Kerberos V change & set Password (RPCSEC_GSS)
TCP
88
Data LIF (NFS, CIFS, iSCSI)
UDP
137
Data LIF (NFS, CIFS)
UDP
138
TCP
139
TCP & UDP
389
LDAP
TCP
445
TCP
464
UDP
464
TCP
749
Kerberos V change & set password (RPCSEC_GSS)
AutoSupport
HTTPS
443
Node management LIF
mysupport.netapp.com
AutoSupport (HTTPS is the default)
HTTP
80
Node management LIF
AutoSupport (only if the transport protocol is changed from HTTPS to HTTP)
TCP
3128
Node management LIF
Console agent
Sending AutoSupport messages through a proxy server on the Console agent, if an outbound internet connection isn't available
Backup to S3
TCP
5010
Intercluster LIF
Backup endpoint or restore endpoint
Back up and restore operations for the Backup to S3 feature
Cluster
All traffic
All traffic
All LIFs on one node
All LIFs on the other node
Intercluster communications (Cloud Volumes ONTAP HA only)
TCP
3000
Node management LIF
HA mediator
ZAPI calls (Cloud Volumes ONTAP HA only)
ICMP
1
Node management LIF
HA mediator
Keep alive (Cloud Volumes ONTAP HA only)
Configuration backups
HTTP
80
Node management LIF
http://<console-agent-IP-address>/occm/offboxconfig
Send configuration backups to the Console agent. ONTAP documentation
DHCP
UDP
68
Node management LIF
DHCP
DHCP client for first-time setup
DHCPS
UDP
67
Node management LIF
DHCP
DHCP server
DNS
UDP
53
Node management LIF and data LIF (NFS, CIFS)
DNS
DNS
NDMP
TCP
18600–18699
Node management LIF
Destination servers
NDMP copy
SMTP
TCP
25
Node management LIF
Mail server
SMTP alerts, can be used for AutoSupport
SNMP
TCP
161
Node management LIF
Monitor server
Monitoring by SNMP traps
UDP
161
Node management LIF
Monitor server
TCP
162
Node management LIF
Monitor server
UDP
162
Node management LIF
Monitor server
SnapMirror
TCP
11104
Intercluster LIF
ONTAP intercluster LIFs
TCP
11105
Intercluster LIF
Syslog
UDP
514
Node management LIF
Syslog server
Syslog forward messages
Rules for the HA mediator external security group
The predefined external security group for the Cloud Volumes ONTAP HA mediator includes the following inbound and outbound rules.
Inbound rules
The predefined security group for the HA mediator includes the following inbound rule.
Protocol Port Source Purpose
TCP
3000
CIDR of the Console agent
RESTful API access from the Console agent
Outbound rules
The predefined security group for the HA mediator opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
The predefined security group for the HA mediator includes the following outbound rules.
All TCP
All
All UDP
All
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by the HA mediator.
Protocol Port Destination Purpose
HTTP
80
IP address of the Console agent on AWS EC2 instance
Download upgrades for the mediator
HTTPS
443
ec2.amazonaws.com
Assist with storage failover
UDP
53
ec2.amazonaws.com
Note Rather than open ports 443 and 53, you can create an interface VPC endpoint from the target subnet to the AWS EC2 service.
Rules for the HA configuration internal security group
The predefined internal security group for a Cloud Volumes ONTAP HA configuration includes the following rules. This security group enables communication between the HA nodes and between the mediator and the nodes.
The Console always creates this security group. You do not have the option to use your own.
Inbound rules
The predefined security group includes the following inbound rules.
All traffic
All
Communication between the HA mediator and HA nodes
Outbound rules
The predefined security group includes the following outbound rules.
All traffic
All
