Cloud Volumes ONTAP
Change the Google Cloud machine type for Cloud Volumes ONTAP
Contributors netapp-ahibbard netapp-manini
You can choose from several machine types when you launch Cloud Volumes ONTAP in Google Cloud. You can change the instance or machine type at any time if you determine that it is undersized or oversized for your needs.
About this task
  • Automatic giveback must be enabled on a Cloud Volumes ONTAP HA pair (this is the default setting). If it isn't, then the operation will fail.
  • Changing the machine type can affect Google Cloud service charges.
  • The operation restarts Cloud Volumes ONTAP.
    For single-node systems, I/O is interrupted.
    For HA pairs, the change is nondisruptive. HA pairs continue to serve data.
    Tip The NetApp Console changes one node at a time by initiating takeover and waiting for give back. NetApp's Quality Assurance team tested both writing and reading files during this process and didn't see any issues on the client side. As connections changed, some retries were observed on the I/O level, but the application layer overcame the rewiring of NFS/CIFS connections.
Steps
  1. On the Systems page, select the system.
  2. On the Overview tab, select the Features panel and then select the pencil icon next to Machine type.
    A screenshot that shows the Machine type setting under the Features panel available in the top right of the Overview page when viewing a system.
If you are using a node-based pay-as-you-go (PAYGO) license, you can optionally choose a different license and machine type by clicking the pencil icon next to License type.
  1. Choose a machine type, select the check box to confirm that you understand the implications of the change, then select Change.
Result
Cloud Volumes ONTAP reboots with the new configuration.
