Modify route tables for Cloud Volumes ONTAP HA pairs in multiple AWS AZs
You can modify the AWS route tables that include routes to the floating IP addresses for an HA pair that's deployed in multiple AWS Availability Zones (AZs). You might do this if new NFS or CIFS clients need to access an HA pair in AWS.
Steps
On the Systems page, select the system.
On the Overview tab, select the Features panel and then select the pencil icon next to Route tables.
Modify the list of selected route tables and then select Save.
Result
The NetApp Console sends an AWS request to modify the route tables.
