Cloud Volumes ONTAP
Configure EMS for Cloud Volumes ONTAP systems
Contributors netapp-manini
The Event Management System (EMS) collects and displays information about events that occur on ONTAP systems. To receive event notifications, you can set event destinations (email addresses, SNMP trap hosts, or syslog servers) and event routes for a particular event severity.
You can configure EMS using the CLI. For instructions, refer to the ONTAP documentation: EMS configuration overview.
