Cloud Volumes ONTAP
Verify Azure marketplace image signature for Cloud Volumes ONTAP on Linux
Contributors netapp-ahibbard netapp-manini
Verification of an exported VHD file signature on Linux includes validating the chain of trust, editing the file, and verifying the signature.
Steps
  1. Download the Azure image file from the NetApp Support Site and extract the digest (.sig) file, public key certificate (.pem) file, and chain certificate (.pem) file.
    Refer to Download the Azure image digest file for more information.
  2. Verify the chain of trust.
    % openssl verify -CAfile Certificate-Chain-9.15.0P1_azure.pem Certificate-9.15.0P1_azure.pem
    Certificate-9.15.0P1_azure.pem: OK
  3. Remove 1 MB (1,048,576 bytes) at the beginning and 512 bytes at the end of the VHD file. When using tail, the -c +K option generates bytes from the Kth byte of the file. Therefore, it passes 1048577 to tail -c.
    % tail -c +1048577 ./9150.01000024.05090105.vhd > ./sign.tmp.tail
    % head -c -512 ./sign.tmp.tail > sign.tmp
    % rm ./sign.tmp.tail
  4. Use OpenSSL to extract the public key from the certificate and verify the stripped file (sign.tmp) with the signature file and the public key.
    The command prompt displays messages indicating success or failure based on the verification.
    % openssl x509 -pubkey -noout -in ./Certificate-9.15.0P1_azure.pem > ./Code-Sign-Cert-Public-key.pub
    % openssl dgst -verify Code-Sign-Cert-Public-key.pub -keyform PEM -sha256 -signature digest.sig -binary ./sign.tmp
    Verification OK
    % openssl dgst -verify Code-Sign-Cert-Public-key.pub -keyform PEM -sha256 -signature digest.sig -binary ./another_file_from_nowhere.tmp
    Verification Failure
  5. Clean up the workspace.
    % rm ./9150.01000024.05090105.vhd ./sign.tmp
    % rm *.sig *.pub *.pem
