Cloud Volumes ONTAP
Move an Azure resource group for Cloud Volumes ONTAP in Azure console
Contributors netapp-ahibbard netapp-manini
Cloud Volumes ONTAP supports Azure resource groups moves but the workflow happens in the Azure console only.
You can move a Cloud Volumes ONTAP system from one resource group to a different resource group in Azure within the same Azure subscription. Moving resource groups between different Azure subscriptions is not supported.
Steps
  1. Remove the Cloud Volumes ONTAP system. Refer to Removing Cloud Volumes ONTAP systems.
  2. Execute the resource group move in the Azure console.
  3. On the Systems page, discover the system.
  4. Look for the new resource group in the information for the system.
Result
The system and its resources (VMs, disks, storage accounts, network interfaces, snapshots) are in the new resource group.
