Plan your Cloud Volumes ONTAP configuration in Google Cloud
When you deploy Cloud Volumes ONTAP in Google Cloud, you can choose a preconfigured system that matches your workload requirements, or you can create your own configuration. If you choose your own configuration, you should understand the options available to you.
Choose a Cloud Volumes ONTAP license
Several licensing options are available for Cloud Volumes ONTAP. Each option enables you to choose a consumption model that meets your needs.
Choose a supported region
Cloud Volumes ONTAP is supported in most Google Cloud regions. View the full list of supported regions.
Choose a supported machine type
Cloud Volumes ONTAP supports several machine types, depending on the license type that you choose.
Understand storage limits
The raw capacity limit for a Cloud Volumes ONTAP system is tied to the license. Additional limits impact the size of aggregates and volumes. You should be aware of these limits as you plan your configuration.
Size your system in Google Cloud
Sizing your Cloud Volumes ONTAP system can help you meet requirements for performance and capacity. You should be aware of a few key points when choosing a machine type, disk type, and disk size:
- Machine type
Look at the supported machine typesand then review details from Google about each supported machine type. Match your workload requirements to the number of vCPUs and memory for the machine type. Note that each CPU core increases networking performance.
Refer to Google documentation: Machine families resource and comparison guide for more details
- Disk types
When you create volumes for Cloud Volumes ONTAP, you need to choose the underlying cloud storage that Cloud Volumes ONTAP uses for a disk. The disk type can be any of the following:
Zonal SSD persistent disks: SSD persistent disks are best for workloads that require high rates of random IOPS.
Zonal Balanced persistent disks: These SSDs balance performance and cost by providing lower IOPS per GB.
Zonal Standard persistent disks : Standard persistent disks are economical and can handle sequential read/write operations.
For more details, refer to the Google Cloud documentation: Zonal Persistent disks (Standard and SSD).
- Disk size
You need to choose an initial disk size when you deploy a Cloud Volumes ONTAP system. After that you can let the NetApp Console manage a system's capacity for you, but if you want to build aggregates yourself, be aware of the following:
All disks in an aggregate must be the same size.
Determine the space that you need, while taking performance into consideration.
The performance of persistent disks scales automatically with disk size and the number of vCPUs available to the system.
Refer to the following for more details:
View default system disks
In addition to the storage for user data, the Console also purchases cloud storage for Cloud Volumes ONTAP system data (boot data, root data, core data, and NVRAM). For planning purposes, it might help for you to review these details before you deploy Cloud Volumes ONTAP.
View the default disks for Cloud Volumes ONTAP system data in Google Cloud.
Google Cloud docs: Cloud Quotas overview
Google Cloud Compute Engine enforces quotas on resource usage so you should ensure that you haven't reached your limit before you deploy Cloud Volumes ONTAP.
The Console agent also requires a system disk. View details about the Console agent's default configuration. |
Collect networking information
When you deploy Cloud Volumes ONTAP in Google Cloud, you need to specify details about your virtual network. You can use a worksheet to collect the information from your administrator.
Network information for a single-node system
| Google Cloud information | Your value |
Region |
Zone |
VPC network |
Subnet |
Firewall policy (if using your own) |
Network information for an HA pair in multiple zones
Region |
Zone for Node 1 |
Zone for Node 2 |
Zone for the mediator |
VPC-0 and subnet |
VPC-1 and subnet |
VPC-2 and subnet |
VPC-3 and subnet |
Network information for an HA pair in a single zone
Region |
Zone |
VPC-0 and subnet |
VPC-1 and subnet |
VPC-2 and subnet |
VPC-3 and subnet |
Choose a write speed
The Console enables you to choose a write speed setting for Cloud Volumes ONTAP, except for high-availability (HA) pairs in Google Cloud. Before you choose a write speed, you should understand the differences between the normal and high settings and risks and recommendations when using high write speed. Learn more about write speed.
Choose a volume usage profile
ONTAP includes several storage efficiency features that can reduce the total amount of storage that you need. When you create a volume in the Console, you can choose a profile that enables these features or a profile that disables them. You should learn more about these features to help you decide which profile to use.
NetApp storage efficiency features provide the following benefits:
- Thin provisioning
Presents more logical storage to hosts or users than you actually have in your physical storage pool. Instead of preallocating storage space, storage space is allocated dynamically to each volume as data is written.
- Deduplication
Improves efficiency by locating identical blocks of data and replacing them with references to a single shared block. This technique reduces storage capacity requirements by eliminating redundant blocks of data that reside in the same volume.
- Compression
Reduces the physical capacity required to store data by compressing data within a volume on primary, secondary, and archive storage.
