Set up Cloud Volumes ONTAP to use a customer-managed key in Azure
Data is automatically encrypted on Cloud Volumes ONTAP in Azure using Azure Storage Service Encryption with a Microsoft-managed key. But you can use your own encryption key instead by following the steps on this page.
Data encryption overview
Cloud Volumes ONTAP data is automatically encrypted in Azure using Azure Storage Service Encryption. The default implementation uses a Microsoft-managed key. No setup is required.
If you want to use a customer-managed key with Cloud Volumes ONTAP, then you need to complete the following steps:
From Azure, create a key vault and then generate a key in that vault.
From the NetApp Console, use the API to create a Cloud Volumes ONTAP system that uses the key.
How data is encrypted
The Console uses a disk encryption set, which enables management of encryption keys with managed disks not page blobs. Any new data disks also use the same disk encryption set. Lower versions will use Microsoft-managed key, instead of the customer-managed key.
After you create a Cloud Volumes ONTAP system that is configured to use a customer-managed key, Cloud Volumes ONTAP data is encrypted as follows.
| Cloud Volumes ONTAP configuration | System disks used for key encryption | Data disks used for key encryption |
Single node |
Azure HA single availability zone with page blobs |
None |
Azure HA single availability zone with shared managed disks |
Azure HA multiple availability zones with shared managed disks |
All Azure storage accounts for Cloud Volumes ONTAP are encrypted using a customer-managed key. If you want to encrypt your storage accounts during their creation, you must create and provide the ID of the resource in the Cloud Volumes ONTAP creation request. This applies for all type of deployments. If you do not provide it, the storage accounts still will be encrypted, but the Console first creates the storage accounts with Microsoft-managed key encryption and then updates the storage accounts to use the customer-managed key.
Key rotation in Cloud Volumes ONTAP
When you configure your encryption keys, you must use the Azure portal to set up and enable automatic key rotation. Creating and enabling a new version of encryption keys ensures that Cloud Volumes ONTAP can automatically detect and use the latest key version for encryption, ensuring your data remains secure without the need for manual intervention.
For information about configuring your keys and setting up key rotation, refer to the following Microsoft Azure documentation topics:
After configuring the keys, ensure that you have selected Enable auto rotation, so that Cloud Volumes ONTAP can use the new keys when the previous keys expire. If you don't enable this option on the Azure portal, Cloud Volumes ONTAP can't automatically detect the new keys, which might cause issues with storage provisioning. |
Create a user-assigned managed identity
You have the option to create a resource called a user-assigned managed identity. Doing so allows you to encrypt your storage accounts when you create a Cloud Volumes ONTAP system. We recommend creating this resource prior to creating a key vault and generating a key.
The resource has the following ID: userassignedidentity.
In Azure, go to Azure services and select Managed Identities.
Select Create.
Provide the following details:
Subscription: Choose a subscription. We recommend choosing the same subscription as the subscription of the Console agent.
Resource group: Use an existing resource group or create a new one.
Region: Optionally, select the same region as the Console agent.
Name: Enter a name for the resource.
Optionally, add tags.
Select Create.
Create a key vault and generate a key
The key vault must reside in the same Azure subscription and region in which you plan to create the Cloud Volumes ONTAP system.
If you created a user-assigned managed identity, while creating the key vault, you should also create an access policy for the key vault.
Create a key vault in your Azure subscription.
Note the following requirements for the key vault:
The key vault must reside in the same region as the Cloud Volumes ONTAP system.
The following options should be enabled:
Soft-delete (this option is enabled by default, but must not be disabled)
Purge protection
Azure Disk Encryption for volume encryption (for single-node systems, HA pairs in multiple zones, and HA single AZ deployments)
Usage of Azure customer-managed encryption keys is contingent upon having Azure Disk encryption enabled for the key vault.
The following option should be enabled if you created a user-assigned managed identity:
Vault access policy
If you selected Vault access policy, select Create to create an access policy for the key vault. If not, skip to step 3.
Select the following permissions:
get
list
decrypt
encrypt
unwrap key
wrap key
verify
sign
Select the user-assigned managed identity (resource) as the principal.
Review and create the access policy.
Generate a key in the key vault.
Note the following requirements for the key:
The key type must be RSA.
The recommended RSA key size is 2048, but other sizes are supported.
Create a system that uses the encryption key
After you create the key vault and generate an encryption key, you can create a new Cloud Volumes ONTAP system that is configured to use the key. These steps are supported by using the API.
If you want to use a customer-managed key with a single node Cloud Volumes ONTAP system, ensure that the Console agent has the following permissions:
"Microsoft.Compute/diskEncryptionSets/read",
"Microsoft.Compute/diskEncryptionSets/write",
"Microsoft.Compute/diskEncryptionSets/delete"
"Microsoft.KeyVault/vaults/deploy/action",
"Microsoft.KeyVault/vaults/read",
"Microsoft.KeyVault/vaults/accessPolicies/write",
"Microsoft.ManagedIdentity/userAssignedIdentities/assign/action"
Obtain the list of key vaults in your Azure subscription by using the following API calls.
For an HA pair:
GET /azure/ha/metadata/vaultsFor single node:
GET /azure/vsa/metadata/vaultsMake note of the name and resourceGroup. You'll need to specify those values in the next step.
Obtain the list of keys within the vault by using the following API call.
For an HA pair:
GET /azure/ha/metadata/keys-vault?resourceGroupName=KeyVaultResourceGroup&vaultName=KeyVaultFor single node:
GET /azure/vsa/metadata/keys-vault?resourceGroupName=KeyVaultResourceGroup&vaultName=KeyVaultMake note of the keyName. You'll need to specify that value (along with the vault name) in the next step.
Create a Cloud Volumes ONTAP system by using the following API call.
For an HA pair use this API call:
POST /azure/ha/working-environmentsThe request body must include the following fields:
"azureEncryptionParameters": { "key": "keyName", "vaultName": "vaultName" }Include the "userAssignedIdentity": " userAssignedIdentityId"field if you created this resource to be used for storage account encryption. -
For a single-node system use this API call:
POST /azure/vsa/working-environmentsThe request body must include the following fields:
You have a new Cloud Volumes ONTAP system that is configured to use your customer-managed key for data encryption.
