Discover E-Series systems
Contributors netapp-tonias
Adding E-Series systems to the NetApp Console allows you to manage your E-Series systems from the Console and get a complete view of your data infrastructure across your hybrid multi-cloud environment.
Required NetApp Console role
Organization admin, Folder or project admin, Storage admin, or System health specialist. Learn about NetApp Console access roles.
Before you begin
You need the following:
  • A NetApp Console Agent installed in a cloud provider or on your premises, with network connectivity to the E-Series system. You must have the Organization admin role to install a Console agent. If you don't know if your organization has a Console agent, or if you need one created, contact your Console administrator. Contact your Organization admin.
  • The domain name or IP address of the storage system controller.
  • Admin credentials for the E-Series system.
Steps
  1. From the navigation menu, select Storage > Management.
  2. From the Systems page, select Add and select On-Premises.
  3. Next to E-Series, select Discover.
  4. On the E-Series Cluster Details page, enter the domain name or IP address of the storage system controller, admin credentials for the system, and then select Add.
