Remove an E-Series from the NetApp Console
Remove an E-Series system if you no longer want to manage it from the NetApp Console.
Required NetApp Console role
Organization admin, Folder or project admin, or Storage admin. Learn about NetApp Console access roles.
Removing the NetApp Console system doesn't affect the E-Series system. You can rediscover it from at any time.
Steps
From the navigation menu, select Storage > Management.
On the Systems page, select the E-Series system.
Select the menu icon and select Remove from Workspace.
Select Remove to confirm.
