Delete an Amazon FSx for NetApp ONTAP file system
To delete an FSx for ONTAP file system, you must first delete any volumes, storage VMs, or replication relationships associated with the file system.
Steps
From the NetApp Console menu, select Storage and then Management.
Select the file system that you want to remove.
Select Enter System.
From FSx for ONTAP in Storage, select the three-dot menu and then select Delete.
Select Delete to confirm deletion.
