Amazon FSx for NetApp ONTAP
Monitor Amazon FSx for NetApp ONTAP operations with Tracker
Contributors netapp-rlithman
Monitor and track the execution of FSx for ONTAP operations and monitor job progress with Tracker in NetApp Console.
About this task
NetApp Console provides Tracker, a job monitoring feature, so you can monitor and track the progress and status of credentials, FSx for ONTAP, and link operations, review details for operation tasks and subtasks, and diagnose any issues or failures.
Several actions are available in Tracker. You can filter jobs by time frame (last 24 hours, 7 days, 14 days, or 30 days), workload, status, and user; find jobs using the search function; and download the jobs table as a CSV file. You can refresh Tracker at any time. And you can quickly retry a failed operation or edit parameters for a failed operation and try the operation again.
Tracker supports two levels of monitoring depending on the operation. Each task, such as file system deployment, displays the task description, status, start time, task duration, user, region, proxy resource, task ID, and all related sub tasks. You can view API responses to understand what happened during the operation.
Tracker task levels with examples
  • Level 1 (parent task): Tracks file system deployment.
  • Level 2 (sub task): Tracks the sub tasks related to file system deployment.
Operation status
Operation status in Tracker is as follows in progress, success, and failed.
Operation frequency
Operation frequency is based on the task type and schedule.
Events retention
Events are retained in the user interface for 30 days.
Track and monitor operations
Track and monitor operations in the NetApp Console with Tracker.
Steps
  1. From the NetApp Console menu, select Workloads and then Administration.
  2. From the Administration menu, select Tracker.
  3. In Tracker, view tasks or use the filters or search to narrow results. You can also download a report of all operations by selecting to Export CSV.
View API request
View the API request in the Codebox for a task in Tracker.
Steps
  1. In Tracker, select a task.
  2. Select the three-dot menu and then select View API request.
Retry a failed operation
Retry a failed operation in Tracker. Retrying the failed operation starts a new task that you can monitor in Tracker.
You can also copy the error message of a failed operation.
Note You can retry the failed operation only once.
Steps
  1. In Tracker, select a failed operation.
  2. Select the three-dot menu and then select Retry.
Result
The operation is re-initiated and appears as a new task in Tracker.
Edit and retry a failed operation
Edit the parameters of the failed operation and retry the operation outside Tracker.
Steps
  2. Select the three-dot menu and then select Edit and retry.
    You are redirected to the operation page, volume creation for example, where you can edit the parameters and retry the operation.
Result
The operation is re-initiated. Go to Tracker to view the status of the operation.
