Amazon FSx for NetApp ONTAP
Remove an Amazon FSx for NetApp ONTAP file system from a project
Contributors netapp-rlithman
Remove an FSx for ONTAP file system from a project in the NetApp Console. This operation dissociates the file system from one project so that you can associate it with another project within the same account.
About this task
Removing an FSx for ONTAP file system from a project removes it from the NetApp Console. It does not delete the FSx for ONTAP file system. You can later rediscover the FSx for ONTAP file system in the same or in a different project from within the same account.
Steps
  1. From the NetApp Console menu, select Storage and then Management.
  2. Select the file system that you want to remove.
  3. Select Enter System.
  4. From FSx for ONTAP in Storage, select the three-dot menu and then select Remove from project.
  5. Select Remove to confirm the removal of the file system from the project.
