Google Cloud NetApp Volumes
Learn about Google Cloud NetApp Volumes
Contributors netapp-sineadd
Google Cloud NetApp Volumes is a fully managed, cloud-based data storage service that provides advanced data management capabilities and highly scalable performance.
NetApp Volumes helps to accelerate deployment times, manage your workloads and applications, and migrate workloads to the cloud while keeping the performance and features of on-premises storage.
Note To start working with Google Cloud NetApp Volumes, you must have the appropriate permissions and the Google Cloud NetApp Volumes admin or Google Cloud NetApp viewer role assigned to you. Assign access roles for NetApp Volumes.
A screenshot of the Google Cloud NetApp Volumes role.
Features
  • Runs enterprise apps faster and more efficiently.
  • Reduces cloud storage costs by up to 90%.
  • Meets mandates for uptime, availability, and security.
  • Supports NFS, SMB and multiprotocol environments.
Cost
Volumes created by Google Cloud NetApp Volumes are charged to your subscription to the service, not through the NetApp Console.
There are no charges to discover a Google Cloud NetApp Volumes region or volume from the NetApp Console.
Getting help
For technical support, log a request via the Google Cloud portal. Choose your Google Cloud subscription and the Google Cloud NetApp Volumes service under Storage. Complete the required information.
For general questions about Google Cloud NetApp Volumes, email NetApp's Google Cloud Team at gcinfo@netapp.com.
For technical issues associated with your cloud volumes, you can create a technical support case from the Google Cloud Console. See obtaining support for details.
