Google Cloud NetApp Volumes
Manage volumes in Google Cloud NetApp Volumes
Contributors netapp-sineadd
You can view your existing volumes and any actions you performed on them.
Required NetApp Console role
Google Cloud NetApp Volumes admin or Google Cloud NetApp Volumes viewer role. Learn about NetApp Console access roles for all services.
View a volume
View the details of your volumes, such as their name, count, region, capacity, used capacity, and storage pool.
Steps
  1. Click Enter system to open the system.
  2. To view a specific volume in the table, select An icon with three dots. and enter the volume name.
  3. To view any labels associated with a volume, in the Labels column, select View.
View the audit log
You can view all the actions performed on volumes in the timeline.
Steps
  1. At the top right, select Settings and then Timeline.
Result
In the Audit logs table, you can view any actions performed on your volumes.
