Optimize clusters using NetApp Digital Advisor
NetApp Digital advisor enables you to optimize the operations, security, and performance of your ONTAP clusters.
Features
You can view the overall status of your storage system, high-level information about the wellness of the system, inventory, planning, upgrades, and valuable insights at a watchlist level using Digital Advisor.
Analyze and optimize the health of your storage systems
Gain insights regarding all the risks to your storage systems and the actions to mitigate the risks
Analyze the performance of your storage devices by viewing the graphical format of performance data
Get details about systems that have exceeded 90% capacity or are nearing 90% capacity
Get information about the hardware and software that have expired or are near-expiration within the next 6 months
Upgrade your storage system software, and update your ONTAP firmware using Ansible
Supported ONTAP systems
Digital Advisor provides information for all the on-premises ONTAP systems and Cloud Volumes ONTAP systems associated with your NetApp Support Site (NSS) account.
