On-premises ONTAP clusters
Remove an on-prem ONTAP system from NetApp Console
Contributors netapp-tonias
Remove an on-premises ONTAP system if you no longer want to manage it from the Console.
Required Console role:
Storage admin. Learn about NetApp Console access roles.
Removing the system doesn't affect the ONTAP cluster. You can rediscover it from the Console at any time.
Steps
  1. From the navigation menu, select Storage > Management.
  2. Select the on-premises ONTAP system on the Systems page.
  3. Select the menu icon and select Remove from workspace.
  4. Select Remove to confirm.
