Amazon S3 storage
Use NetApp data services with S3 buckets
Contributors netapp-tonias netapp-sineadd
After you discover S3 buckets in NetApp Console, you can use NetApp data services for backup, tiering, classification, and data synchronization.
  • Use NetApp Backup and Recovery to back up data from your on-premises ONTAP and Cloud Volumes ONTAP systems to S3 object storage.
    To get started, go to the Systems page and drag and drop an on-premises ONTAP or Cloud Volumes ONTAP system on your Amazon S3 system.
  • Use NetApp Cloud Tiering to tier inactive data from on-premises ONTAP clusters to S3 object storage.
    To get started, go to the Systems page and drag and drop an on-premises ONTAP system on your Amazon S3 system.
  • Use NetApp Copy and Sync to synchronize data to or from S3 buckets.
    To get started, go to the Systems page and drag and drop the source system on the target system. Your Amazon S3 system can be either the source or target.
    You can also select your Amazon S3 system and click Copy & sync from the Services panel to synchronize data to or from S3 buckets.
  • Use NetApp Data Classification to scan your S3 buckets for personal and sensitive data. NetApp Data Classification can scan any bucket in the account, regardless of whether it was created for a NetApp solution.
    To get started, select your Amazon S3 system and select the appropriate option from the Classification section of the Services panel to initiate scanning of your S3 buckets.
