Remove a StorageGRID system
Remove a StorageGRID system if you no longer want to manage it from the NetApp Console.
Required NetApp Console role:
Super admin or Storage admin. Learn about NetApp Console access roles.
Removing the system from the Console doesn't affect the StorageGRID system. You can re-add it to the Console at any time.
Steps
From the navigation menu, select Storage > Management.
From the Systems page, open the StorageGRID system.
From the standard view, select the menu icon and select Remove from Workspace.
Select Remove to confirm.
