StorageGRID appliances
Install the SGF6212 into a cabinet or rack
Contributors netapp-ivanad
You install a set of rails for the appliance in your cabinet or rack, and then slide the appliance onto the rails.
Before you begin
  • You have reviewed the Safety Notices document included in the box and understand the precautions for moving and installing hardware.
  • You have the instructions packaged with the rail kit.
Steps
  1. Carefully follow the instructions for the rail kit to install the rails in your cabinet or rack.
  2. On the two rails installed in the cabinet or rack, extend the movable parts of the rails until you hear a click.
    Appliance rails extended
  3. Insert the appliance into the rails.
  4. Slide the appliance into the cabinet or rack.
    When you can't move the appliance any further, pull the blue latches on both sides of the chassis to slide the appliance all the way in.
    Appliance Sliding on Rails
  5. Tighten the captive screws on the appliance front panel to secure the appliance in the rack.
    Appliance rack retaining screws
    Note Don't attach the front bezel until after you power on the appliance.
