StorageGRID appliances
Prepare the site for StorageGRID appliance installation
Contributors netapp-ivanad netapp-perveilerk netapp-pcarriga
Before installing the appliance, you must make sure that the site and the cabinet or rack you plan to use meet the specifications for a StorageGRID appliance.
Steps
  1. Confirm that the site meets the requirements for temperature, humidity, altitude range, airflow, heat dissipation, wiring, power, and grounding. See the NetApp Hardware Universe for more information.
  2. Confirm that your location provides the correct voltage of AC power:
    Model Requirement
    SG100 and SG1000
    120 to 240-volts AC
    SG110 and SG1100
    100 to 240 volts AC
    SG120 and SG1200
    240 volts AC
    SG5712
    120 to 240 volts AC
    SG5760
    240-volts AC
    SG5812
    120 to 240-volts AC
    SG5860
    240-volts AC
    SGF6024
    120-volts AC
    SG6060
    240-volts AC
    SGF6112
    240-volts AC
    SG6160
    240-volts AC
    SGF6212
    240 volts AC
    SG6260
    240 volts AC
  3. Confirm that your location meets the power requirements for your appliance:
    Model Average power required (W) Maximum power required (W)
    SG100
    273
    400
    SG1000
    337
    600
    SG110
    352
    500
    SG1100
    422
    700
    SG120
    432
    519
    SG1200
    557
    668
    SG5712
    578
    700
    SG5760
    1394
    1800
    SG5812
    449
    600
    SG5860
    1048
    1300
    SGF6024
    1027
    1900
    SG6060
    1484
    2300
    SGF6112
    446
    700
    SG6160
    1312
    1800
    SGF6212
    673
    808
    SG6260
    580
    696
    Note The power supplies in StorageGRID appliances are rated for significantly higher wattages than the StorageGRID appliance hardware uses, even during periods of maximum power consumption. NetApp recommends using the NetApp Hardware Universe to determine whether a proposed rack layout that includes StorageGRID appliances is compatible with your rack power budget.
  4. Obtain a 19-inch (48.3-cm) cabinet or rack to fit shelves of the following size (without cables).
    SG100 and SG1000
    Height Width Depth Maximum weight
    1.70 in.
    (4.32 cm)
    17.32 in.
    (44.0 cm)
    32.0 in.
    (81.3 cm)
    39 lb.
    (17.7 kg)
    SG110 and SG1100
    1.70 in.
    (4.31 cm)
    18.98 in.
    (48.2 cm)
    33.11 in.
    (84.1 cm)
    43.83 lb.
    (19.88 kg)
    SG120 and SG1200
    Appliance model Height Width Depth Maximum weight
    SG120
    1.70 in.
    (4.32 cm)
    18.98 in.
    (48.21 cm)
    30.56 in.
    (77.62 cm)
    42.13 lb.
    (19.11 kg)
    SG1200
    1.70 in.
    (4.32 cm)
    18.98 in.
    (48.21 cm)
    30.56 in.
    (77.62 cm)
    43.43 lb.
    (19.70 kg)
    SG5700
    SG5712
    (12 drives)
    3.41 in.
    (8.68 cm)
    17.6 in.
    (44.7 cm)
    21.1 in.
    (53.6 cm)
    63.9 lb
    (29.0 kg)
    SG5760
    (60 drives)
    6.87 in.
    (17.46 cm)
    17.66 in.
    (44.86 cm)
    38.25 in.
    (97.16 cm)
    250 lb.
    (113 kg)
    SG5800
    SG5812
    (12 drives)
    3.4 in.
    (8.6 cm)
    17.6 in.
    (44.8 cm)
    21.1 in.
    (53.6 cm)
    64.92 lb
    (29.45 kg)
    SG5860
    (60 drives)
    7.0 in.
    (17.8 cm)
    17.6 in.
    (44.8 cm)
    37.8 in.
    (92.2 cm)
    253.0 lb.
    (114.76 kg)
    SG6000
    Type of shelf Height Width Depth Maximum weight
    E2860 controller shelf (SG6060)
    6.87 in.
    (17.46 cm)
    17.66 in.
    (44.86 cm)
    38.25 in.
    (97.16 cm)
    250 lb.
    (113 kg)
    Expansion shelf (SG6060) - Optional
    6.87 in.
    (17.46 cm)
    17.66 in.
    (44.86 cm)
    38.25 in.
    (97.16 cm)
    250 lb.
    (113 kg)
    EF570 controller shelf (SGF6024)
    3.35 in.
    (8.50 cm)
    17.66 in.
    (44.86 cm)
    19.00 in.
    (48.26 cm)
    51.74 lb.
    (23.47 kg)
    SG6000-CN compute controller
    1.70 in.
    (4.32 cm)
    17.32 in.
    (44.0 cm)
    32.0 in.
    (81.3 cm)
    39 lb.
    (17.7 kg)
    SG6100
    Appliance model/type of shelf Height Width Depth Maximum weight
    SGF6112 appliance
    1.70 in.
    (4.31 cm)
    17.32 in.
    (44.0 cm)
    33.11 in.
    (84.1 cm)
    43.83 lb.
    (19.88 kg)
    SG6100-CN compute controller (SG6160)
    1.70 in.
    (4.32 cm)
    17.32 in.
    (44.0 cm)
    33.11 in.
    (84.1 cm)
    40.98 lb.
    (18.59 kg)
    E4060 controller shelf (SG6160)
    6.87 in.
    (17.45 cm)
    17.64 in.
    (44.8 cm)
    36.3 in.
    (97.16 cm)
    223.58 lb.
    (101.42 kg)
    Expansion shelf (SG6160) - Optional
    6.87 in.
    (17.45 cm)
    17.64 in.
    (44.8 cm)
    36.3 in.
    (97.16 cm)
    223.58 lb.
    (101.42 kg)
    SG6200
    SGF6212 appliance
    1.70 in. (4.32 cm)
    18.98 in. (48.21 cm)
    30.56 in. (77.62 cm)
    55.98 lb. (25.39 kg)
    SG6200-CN compute controller (SG6260)
    1.70 in. (4.32 cm)
    44.0 lb. (19.70 kg)
    E4060 controller shelf (SG6260)
    6.87 in.
    (17.45 cm)
    17.64 in.
    (44.8 cm)
    36.3 in.
    (97.16 cm)
    223.58 lb.
    (101.42 kg)
    Expansion shelf (SG6260) - Optional
    6.87 in.
    (17.45 cm)
    17.64 in.
    (44.8 cm)
    36.3 in.
    (97.16 cm)
    223.58 lb.
    (101.42 kg)
  5. Decide where you are going to install the appliance.
    Caution When installing the E2860 or E4000 controller shelf or optional expansion shelves, install hardware from the bottom to the top of the rack or cabinet to prevent the equipment from tipping over. To ensure that the heaviest equipment is at the bottom of the cabinet or rack, install the SG6000-CN, SG6100-CN or SG6200-CN controller above the E2860 or E4000 controller shelf and expansion shelves.
    Note Before committing to the installation, verify that the cables shipped with an SG6000, SG6100, or SG6200 appliance, or cables that you supply, are long enough for the planned layout.
  6. Install any required network switches. See the NetApp Interoperability Matrix Tool for compatibility information.
