Install the SG6200-CN controller for an SG6260
You install a set of rails for the SG6200-CN controller in your cabinet or rack, and then slide the controller onto the rails.
You have reviewed the Safety Notices document included in the box, and understand the precautions for moving and installing hardware.
You have the instructions packaged with the rail kit.
You have installed the E4000 controller shelf and drives.
Carefully follow the instructions for the rail kit to install the rails in your cabinet or rack.
On the two rails installed in the cabinet or rack, extend the movable parts of the rails until you hear a click.
Insert the SG6200-CN controller into the rails.
Slide the controller into the cabinet or rack.
When you can't move the controller any further, pull the blue latches on both sides of the chassis to slide the controller all the way in.
Don't attach the front bezel until after you power on the controller. -
Tighten the captive screws on the controller front panel to secure the controller in the rack.
