StorageGRID appliances
Verify port-level network connections on StorageGRID appliances
Contributors netapp-perveilerk netapp-pcarriga
To ensure that access between the StorageGRID Appliance Installer and other nodes is not obstructed by firewalls, confirm that the StorageGRID Appliance Installer can connect to a specific TCP port or set of ports at the specified IP address or range of addresses.
About this task
Using the list of ports provided in the StorageGRID Appliance Installer, you can test the connectivity between the appliance and the other nodes in your Grid Network.
Additionally, you can test connectivity on the Admin and Client Networks and on UDP ports, such as those used for external NFS or DNS servers. For a list of these ports, see the network port reference.
Note The Grid Network ports listed in the port connectivity table are valid only for StorageGRID version 11.7 or later. To verify which ports are correct for each node type, you should always consult the networking guidelines for your version of StorageGRID.
Steps
  1. From the StorageGRID Appliance Installer, click Configure Networking > Port Connectivity Test (nmap).
    The Port Connectivity Test page appears.
    The port connectivity table lists node types that require TCP connectivity on the Grid Network. For each node type, the table lists the Grid Network ports that should be accessible to your appliance.
    You can test the connectivity between the appliance ports listed in the table and the other nodes in your Grid Network.
  2. From the Network drop-down, select the network you want to test: Grid, Admin, or Client.
  3. Specify a space-separated list or a range of IPv4 addresses for the hosts on that network.
  4. Enter a TCP port number, a list of ports separated by commas, or a range of ports.
  5. Click Test Connectivity.
    • If the selected port-level network connections are valid, the “Port connectivity test passed” message appears in a green banner. The nmap command output is listed below the banner. Unreachable hosts will not appear in the nmap command output.
    • If a port-level network connection is made to the remote host, but the host is not listening on one or more of the selected ports, the “Port connectivity test failed” message appears in a yellow banner. The nmap command output is listed below the banner. Unreachable hosts will not appear in the nmap command output.
      Any remote port the host is not listening to has a state of “closed.” For example, you might see this yellow banner when the node you are trying to connect to is in a pre-installed state and the StorageGRID NMS service is not yet running on that node.
    • If a port-level network connection can't be made for one or more selected ports, the “Port connectivity test failed” message appears in a red banner. The nmap command output is listed below the banner. Unreachable hosts will not appear in the nmap command output.
      The red banner indicates that a TCP connection attempt to a port on the remote host was made, but nothing was returned to the sender. When no response is returned, the port has a state of "filtered" and is likely blocked by a firewall.
      Note Ports with “closed” are also listed.
