StorageGRID appliances
Turn the SG6000-CN controller identify LED on and off
Contributors netapp-perveilerk netapp-pcarriga
The blue identify LED on the front and back of the controller can be turned on to help locate the appliance in a data center.
Before you begin
You have the BMC IP address of the controller you want to identify.
Steps
  1. Access the controller BMC interface.
  2. Select Server Identify.
    The current status of the identify LED is selected.
  3. Select ON or OFF, and then select Perform Action.
    When you select ON, the blue identify LEDs light on the front (shown) and rear of the appliance.
    Front identify LED - on
    Note If a bezel is installed on the controller, it might be difficult to see the front identify LED.
  4. Turn the LED on and off as needed.
