StorageGRID appliances
Relocate SGF6212 or SG6200-CN in cabinet or rack
Contributors netapp-ivanad
Remove the SGF6212 or SG6200-CN from a cabinet or rack to access the top cover or to move the appliance to a different location, then reinstall the appliance into a cabinet or rack when hardware maintenance is complete.
Remove SGF6212 or SG6200-CN from cabinet or rack
Before you begin
Steps
  1. Label and then disconnect the appliance power cables.
  2. Wrap the strap end of the ESD wristband around your wrist, and secure the clip end to a metal ground to prevent static discharge.
  3. Label and then disconnect the appliance data cables and any SFP+ or SFP28 transceivers.
    Note To prevent degraded performance, don't twist, fold, pinch, or step on the cables.
  4. Loosen the two captive screws on the appliance front panel.
    SGF6212 or SG6200-CN rack retaining screws
  5. Slide the SGF6212 or SG6200-CN forward out of the rack until the mounting rails are fully extended and you hear the latches on both sides click.
    The appliance top cover is accessible.
  6. Optional: If you are fully removing the appliance from the cabinet or rack, follow the instructions for the rail kit to remove the appliance from the rails.
After replacing the part, return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Parts Return & Replacements page for further information.
Reinstall SGF6212 or SG6200-CN into cabinet or rack
Before you begin
You have reinstalled the appliance cover.
Steps
  1. Press the blue rail releases both rack rails at the same time and slide the SGF6212 or SG6200-CN into the rack until it is fully seated.
    When you can't move the controller any further, pull the blue latches on both sides of the chassis to slide the controller all the way in.
    SG6000 Sliding on Rails
    Note Don't attach the front bezel until after you power on the controller.
  2. Tighten the captive screws on the controller front panel to secure the controller in the rack.
    SG6060 rack retaining screws
  3. Wrap the strap end of the ESD wristband around your wrist, and secure the clip end to a metal ground to prevent static discharge.
  4. Reconnect the controller data cables and any SFP+, SFP28, QSFP+, QSFP28, or QSFP56 transceivers.
  5. Reconnect the controller power cables.
After you finish
Restart the appliance.
