Configure a backend with ONTAP SAN drivers
Learn about configuring an ONTAP backend with ONTAP SAN drivers.
User permissions
Astra Trident expects to be run as either an ONTAP or SVM administrator, typically using the admin
cluster user or a vsadmin
SVM user, or a user with a different name that has the same role. For Amazon FSx for NetApp ONTAP deployments, Astra Trident expects to be run as either an ONTAP or SVM administrator, using the cluster fsxadmin
user or a vsadmin
SVM user, or a user with a different name that has the same role. The fsxadmin
user is a limited replacement for the cluster admin user.
If you use the limitAggregateUsage parameter, cluster admin permissions are required. When using Amazon FSx for NetApp ONTAP with Astra Trident, the limitAggregateUsage parameter will not work with the vsadmin and fsxadmin user accounts. The configuration operation will fail if you specify this parameter.
