Use CSI Topology
Astra Trident can selectively create and attach volumes to nodes present in a Kubernetes cluster by making use of the CSI Topology feature. Using the CSI Topology feature, access to volumes can be limited to a subset of nodes, based on regions and availability zones. Cloud providers today enable Kubernetes administrators to spawn nodes that are zone based. Nodes can be located in different availability zones within a region, or across various regions. To facilitate the provisioning of volumes for workloads in a multi-zone architecture, Astra Trident uses CSI Topology.
Learn more about the CSI Topology feature here. |
Kubernetes provides two unique volume binding modes:
With
VolumeBindingMode
set toImmediate
, Astra Trident creates the volume without any topology awareness. Volume binding and dynamic provisioning are handled when the PVC is created. This is the defaultVolumeBindingMode
and is suited for clusters that do not enforce topology constraints. Persistent Volumes are created without having any dependency on the requesting pod’s scheduling requirements. -
With
VolumeBindingMode
set toWaitForFirstConsumer
, the creation and binding of a Persistent Volume for a PVC is delayed until a pod that uses the PVC is scheduled and created. This way, volumes are created to meet the scheduling constraints that are enforced by topology requirements.
The WaitForFirstConsumer binding mode does not require topology labels. This can be used independent of the CSI Topology feature.
To make use of CSI Topology, you need the following:
A Kubernetes cluster running 1.17 or later.
$ kubectl version Client Version: version.Info{Major:"1", Minor:"19", GitVersion:"v1.19.3", GitCommit:"1e11e4a2108024935ecfcb2912226cedeafd99df", GitTreeState:"clean", BuildDate:"2020-10-14T12:50:19Z", GoVersion:"go1.15.2", Compiler:"gc", Platform:"linux/amd64"} Server Version: version.Info{Major:"1", Minor:"19", GitVersion:"v1.19.3", GitCommit:"1e11e4a2108024935ecfcb2912226cedeafd99df", GitTreeState:"clean", BuildDate:"2020-10-14T12:41:49Z", GoVersion:"go1.15.2", Compiler:"gc", Platform:"linux/amd64"}
Nodes in the cluster should have labels that introduce topology awareness (
topology.kubernetes.io/region
andtopology.kubernetes.io/zone
). These labels should be present on nodes in the cluster before Astra Trident is installed for Astra Trident to be topology aware.$ kubectl get nodes -o=jsonpath='{range .items[*]}[{.metadata.name}, {.metadata.labels}]{"\n"}{end}' | grep --color "topology.kubernetes.io" [node1, {"beta.kubernetes.io/arch":"amd64","beta.kubernetes.io/os":"linux","kubernetes.io/arch":"amd64","kubernetes.io/hostname":"node1","kubernetes.io/os":"linux","node-role.kubernetes.io/master":"","topology.kubernetes.io/region":"us-east1","topology.kubernetes.io/zone":"us-east1-a"}] [node2, {"beta.kubernetes.io/arch":"amd64","beta.kubernetes.io/os":"linux","kubernetes.io/arch":"amd64","kubernetes.io/hostname":"node2","kubernetes.io/os":"linux","node-role.kubernetes.io/worker":"","topology.kubernetes.io/region":"us-east1","topology.kubernetes.io/zone":"us-east1-b"}] [node3, {"beta.kubernetes.io/arch":"amd64","beta.kubernetes.io/os":"linux","kubernetes.io/arch":"amd64","kubernetes.io/hostname":"node3","kubernetes.io/os":"linux","node-role.kubernetes.io/worker":"","topology.kubernetes.io/region":"us-east1","topology.kubernetes.io/zone":"us-east1-c"}]
Step 1: Create a topology-aware backend
Astra Trident storage backends can be designed to selectively provision volumes based on availability zones. Each backend can carry an optional supportedTopologies
block that represents a list of zones and regions that must be supported. For StorageClasses that make use of such a backend, a volume would only be created if requested by an application that is scheduled in a supported region/zone.
Here is what an example backend definition looks like:
{ "version": 1, "storageDriverName": "ontap-san", "backendName": "san-backend-us-east1", "managementLIF": "192.168.27.5", "svm": "iscsi_svm", "username": "admin", "password": "xxxxxxxxxxxx", "supportedTopologies": [ {"topology.kubernetes.io/region": "us-east1", "topology.kubernetes.io/zone": "us-east1-a"}, {"topology.kubernetes.io/region": "us-east1", "topology.kubernetes.io/zone": "us-east1-b"} ] }
supportedTopologies is used to provide a list of regions and zones per backend. These regions and zones represent the list of permissible values that can be provided in a StorageClass. For StorageClasses that contain a subset of the regions and zones provided in a backend, Astra Trident will create a volume on the backend.
You can define supportedTopologies
per storage pool as well. See the following example:
{"version": 1, "storageDriverName": "ontap-nas", "backendName": "nas-backend-us-central1", "managementLIF": "172.16.238.5", "svm": "nfs_svm", "username": "admin", "password": "Netapp123", "supportedTopologies": [ {"topology.kubernetes.io/region": "us-central1", "topology.kubernetes.io/zone": "us-central1-a"}, {"topology.kubernetes.io/region": "us-central1", "topology.kubernetes.io/zone": "us-central1-b"} ] "storage": [ { "labels": {"workload":"production"}, "region": "Iowa-DC", "zone": "Iowa-DC-A", "supportedTopologies": [ {"topology.kubernetes.io/region": "us-central1", "topology.kubernetes.io/zone": "us-central1-a"} ] }, { "labels": {"workload":"dev"}, "region": "Iowa-DC", "zone": "Iowa-DC-B", "supportedTopologies": [ {"topology.kubernetes.io/region": "us-central1", "topology.kubernetes.io/zone": "us-central1-b"} ] } ] }
In this example, the region
and zone
labels stand for the location of the storage pool. topology.kubernetes.io/region
and topology.kubernetes.io/zone
dictate where the storage pools can be consumed from.
Step 2: Define StorageClasses that are topology aware
Based on the topology labels that are provided to the nodes in the cluster, StorageClasses can be defined to contain topology information. This will determine the storage pools that serve as candidates for PVC requests made, and the subset of nodes that can make use of the volumes provisioned by Trident.
apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: netapp-san-us-east1 provisioner: csi.trident.netapp.io volumeBindingMode: WaitForFirstConsumer allowedTopologies: - matchLabelExpressions: - key: topology.kubernetes.io/zone values: - us-east1-a - us-east1-b - key: topology.kubernetes.io/region values: - us-east1 parameters: fsType: "ext4"
In the StorageClass definition provided above, volumeBindingMode
is set to WaitForFirstConsumer
. PVCs that are requested with this StorageClass will not be acted upon until they are referenced in a pod. And, allowedTopologies
provides the zones and region to be used. The netapp-san-us-east1
StorageClass will create PVCs on the san-backend-us-east1
backend defined above.
Step 3: Create and use a PVC
With the StorageClass created and mapped to a backend, you can now create PVCs.
See the example spec
below:
--- kind: PersistentVolumeClaim apiVersion: v1 metadata: name: pvc-san spec: accessModes: - ReadWriteOnce resources: requests: storage: 300Mi storageClassName: netapp-san-us-east1
Creating a PVC using this manifest would result in the following:
$ kubectl create -f pvc.yaml persistentvolumeclaim/pvc-san created $ kubectl get pvc NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS AGE pvc-san Pending netapp-san-us-east1 2s $ kubectl describe pvc Name: pvc-san Namespace: default StorageClass: netapp-san-us-east1 Status: Pending Volume: Labels: <none> Annotations: <none> Finalizers: [kubernetes.io/pvc-protection] Capacity: Access Modes: VolumeMode: Filesystem Mounted By: <none> Events: Type Reason Age From Message ---- ------ ---- ---- ------- Normal WaitForFirstConsumer 6s persistentvolume-controller waiting for first consumer to be created before binding
For Trident to create a volume and bind it to the PVC, use the PVC in a pod. See the following example:
apiVersion: v1 kind: Pod metadata: name: app-pod-1 spec: affinity: nodeAffinity: requiredDuringSchedulingIgnoredDuringExecution: nodeSelectorTerms: - matchExpressions: - key: topology.kubernetes.io/region operator: In values: - us-east1 preferredDuringSchedulingIgnoredDuringExecution: - weight: 1 preference: matchExpressions: - key: topology.kubernetes.io/zone operator: In values: - us-east1-a - us-east1-b securityContext: runAsUser: 1000 runAsGroup: 3000 fsGroup: 2000 volumes: - name: vol1 persistentVolumeClaim: claimName: pvc-san containers: - name: sec-ctx-demo image: busybox command: [ "sh", "-c", "sleep 1h" ] volumeMounts: - name: vol1 mountPath: /data/demo securityContext: allowPrivilegeEscalation: false
This podSpec instructs Kubernetes to schedule the pod on nodes that are present in the us-east1
region, and choose from any node that is present in the us-east1-a
or us-east1-b
zones.
See the following output:
$ kubectl get pods -o wide NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES app-pod-1 1/1 Running 0 19s 192.168.25.131 node2 <none> <none> $ kubectl get pvc -o wide NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS AGE VOLUMEMODE pvc-san Bound pvc-ecb1e1a0-840c-463b-8b65-b3d033e2e62b 300Mi RWO netapp-san-us-east1 48s Filesystem
Update backends to include supportedTopologies
Pre-existing backends can be updated to include a list of supportedTopologies
using tridentctl backend update
. This will not affect volumes that have already been provisioned, and will only be used for subsequent PVCs.
