Work with volumes
You can easily create, clone, and remove volumes using the standard docker volume
commands with the Astra Trident driver name specified when needed.
Create a volume
Create a volume with a driver using the default name:
docker volume create -d netapp --name firstVolume
Create a volume with a specific Astra Trident instance:
docker volume create -d ntap_bronze --name bronzeVolume
If you do not specify any options, the defaults for the driver are used. -
Override the default volume size. See the following example to create a 20GiB volume with a driver:
docker volume create -d netapp --name my_vol --opt size=20G
Volume sizes are expressed as strings containing an integer value with optional units (example: 10G, 20GB, 3TiB). If no units are specified, the default is G. Size units can be expressed either as powers of 2 (B, KiB, MiB, GiB, TiB) or powers of 10 (B, KB, MB, GB, TB). Shorthand units use powers of 2 (G = GiB, T = TiB, …).
Remove a volume
Remove the volume just like any other Docker volume:
docker volume rm firstVolume
When using the solidfire-san
driver, the above example deletes and purges the volume.
Perform the steps below to upgrade Astra Trident for Docker.
Clone a volume
When using the ontap-nas
, ontap-san
, solidfire-san
, and gcp-cvs storage drivers
, Astra Trident can clone volumes. When using the ontap-nas-flexgroup
or ontap-nas-economy
drivers, cloning is not supported. Creating a new volume from an existing volume will result in a new snapshot being created.
Inspect the volume to enumerate snapshots:
docker volume inspect <volume_name>
Create a new volume from an existing volume. This will result in a new snapshot being created:
docker volume create -d <driver_name> --name <new_name> -o from=<source_docker_volume>
Create a new volume from an existing snapshot on a volume. This will not create a new snapshot:
docker volume create -d <driver_name> --name <new_name> -o from=<source_docker_volume> -o fromSnapshot=<source_snap_name>
Example
[me@host ~]$ docker volume inspect firstVolume [ { "Driver": "ontap-nas", "Labels": null, "Mountpoint": "/var/lib/docker-volumes/ontap-nas/netappdvp_firstVolume", "Name": "firstVolume", "Options": {}, "Scope": "global", "Status": { "Snapshots": [ { "Created": "2017-02-10T19:05:00Z", "Name": "hourly.2017-02-10_1505" } ] } } ] [me@host ~]$ docker volume create -d ontap-nas --name clonedVolume -o from=firstVolume clonedVolume [me@host ~]$ docker volume rm clonedVolume [me@host ~]$ docker volume create -d ontap-nas --name volFromSnap -o from=firstVolume -o fromSnapshot=hourly.2017-02-10_1505 volFromSnap [me@host ~]$ docker volume rm volFromSnap
Access externally created volumes
You can access externally created block devices (or their clones) by containers using Trident only if they have no partitions and if their filesystem is supported by Astra Trident (for example: an ext4
-formatted /dev/sdc1
will not be accessible via Astra Trident).
