Astra Trident
ONTAP drivers
Astra Trident provides five unique ONTAP storage drivers for communicating with ONTAP clusters. Learn more about how each driver handles the creation of volumes and access control and their capabilities.
Driver Protocol VolumeMode Access modes supported File systems supported
ontap-nas
NFS
Filesystem
RWO,RWX,ROX
"", nfs
ontap-nas-economy
NFS
Filesystem
RWO,RWX,ROX
"", nfs
ontap-nas-flexgroup
NFS
Filesystem
RWO,RWX,ROX
"", nfs
ontap-san
iSCSI
Block
RWO,ROX,RWX
No Filesystem. Raw block device
ontap-san
iSCSI
Filesystem
RWO,ROX
xfs, ext3, ext4
ontap-san-economy
iSCSI
Block
RWO,ROX,RWX
ontap-san-economy
iSCSI
Filesystem
RWO,ROX
xfs, ext3, ext4
Note ONTAP backends can be authenticated by using login credentials for a security role (username/password) or using the private key and the certificate that is installed on the ONTAP cluster. You can update existing backends to move from one authentication mode to the other with tridentctl update backend.
