Upgrade with tridentctl
You can easily upgrade an existing Astra Trident installation by using tridentctl.
Considerations before upgrading
When upgrading to the latest release of Astra Trident, consider the following:
Starting with Trident 20.01, only the beta release of volume snapshots is supported. Kubernetes administrators should take care to safely back up or convert the alpha snapshot objects to beta to retain the legacy alpha snapshots.
The beta release of volume snapshots introduces a modified set of CRDs and a snapshot controller, both of which should be set up before installing Astra Trident. This blog discusses the steps involved in migrating alpha volume snapshots to the beta format.
Uninstalling and reinstalling Astra Trident acts as an upgrade. When you uninstall Trident, the Persistent Volume Claim (PVC) and Persistent Volume (PV) used by the Astra Trident deployment are not deleted. PVs that have already been provisioned will remain available while Astra Trident is offline, and Astra Trident will provision volumes for any PVCs that are created in the interim once it is back online.
When upgrading Astra Trident, do not interrupt the upgrade process. Ensure that the installer runs to completion. |
Next steps after upgrade
To make use of the rich set of features that are available in newer Trident releases (such as, On-Demand Volume Snapshots), you can upgrade the volumes by using the tridentctl upgrade command.
If there are legacy volumes, you should upgrade them from a NFS/iSCSI type to the CSI type to be able to use the complete set of new features in Astra Trident. A legacy PV that has been provisioned by Trident supports the traditional set of features.
Consider the following when deciding to upgrade volumes to the CSI type:
You might not need to upgrade all the volumes. Previously created volumes will continue to be accessible and function normally.
A PV can be mounted as part of a deployment/StatefulSet when upgrading. It is not required to bring down the deployment/StatefulSet.
You cannot attach a PV to a standalone pod when upgrading. You should shut down the pod before upgrading the volume.
You can upgrade only a volume that is bound to a PVC. Volumes that are not bound to PVCs should be removed and imported before upgrading.
Volume upgrade example
Here is an example that shows how a volume upgrade is performed.
Run
kubectl get pvto list the PVs.kubectl get pv NAME CAPACITY ACCESS MODES RECLAIM POLICY STATUS CLAIM STORAGECLASS REASON AGE default-pvc-1-a8475 1073741824 RWO Delete Bound default/pvc-1 standard 19h default-pvc-2-a8486 1073741824 RWO Delete Bound default/pvc-2 standard 19h default-pvc-3-a849e 1073741824 RWO Delete Bound default/pvc-3 standard 19h default-pvc-4-a84de 1073741824 RWO Delete Bound default/pvc-4 standard 19h trident 2Gi RWO Retain Bound trident/trident 19h
There are currently four PVs that have been created by Trident 20.07, using the
netapp.io/tridentprovisioner. -
Run
kubectl describe pvto get the details of the PV.kubectl describe pv default-pvc-2-a8486 Name: default-pvc-2-a8486 Labels: <none> Annotations: pv.kubernetes.io/provisioned-by: netapp.io/trident volume.beta.kubernetes.io/storage-class: standard Finalizers: [kubernetes.io/pv-protection] StorageClass: standard Status: Bound Claim: default/pvc-2 Reclaim Policy: Delete Access Modes: RWO VolumeMode: Filesystem Capacity: 1073741824 Node Affinity: <none> Message: Source: Type: NFS (an NFS mount that lasts the lifetime of a pod) Server: 10.xx.xx.xx Path: /trid_1907_alpha_default_pvc_2_a8486 ReadOnly: falseThe PV was created by using the
netapp.io/tridentprovisioner and is of the type NFS. To support all the new features provided by Astra Trident, this PV should be upgraded to the CSI type. -
Run the
tridenctl upgrade volume <name-of-trident-volume>command to upgrade a legacy Astra Trident volume to the CSI spec../tridentctl get volumes -n trident +---------------------+---------+---------------+----------+--------------------------------------+--------+---------+ | NAME | SIZE | STORAGE CLASS | PROTOCOL | BACKEND UUID | STATE | MANAGED | +---------------------+---------+---------------+----------+--------------------------------------+--------+---------+ | default-pvc-2-a8486 | 1.0 GiB | standard | file | c5a6f6a4-b052-423b-80d4-8fb491a14a22 | online | true | | default-pvc-3-a849e | 1.0 GiB | standard | file | c5a6f6a4-b052-423b-80d4-8fb491a14a22 | online | true | | default-pvc-1-a8475 | 1.0 GiB | standard | file | c5a6f6a4-b052-423b-80d4-8fb491a14a22 | online | true | | default-pvc-4-a84de | 1.0 GiB | standard | file | c5a6f6a4-b052-423b-80d4-8fb491a14a22 | online | true | +---------------------+---------+---------------+----------+--------------------------------------+--------+---------+ ./tridentctl upgrade volume default-pvc-2-a8486 -n trident +---------------------+---------+---------------+----------+--------------------------------------+--------+---------+ | NAME | SIZE | STORAGE CLASS | PROTOCOL | BACKEND UUID | STATE | MANAGED | +---------------------+---------+---------------+----------+--------------------------------------+--------+---------+ | default-pvc-2-a8486 | 1.0 GiB | standard | file | c5a6f6a4-b052-423b-80d4-8fb491a14a22 | online | true | +---------------------+---------+---------------+----------+--------------------------------------+--------+---------+
Run a
kubectl describe pvto verify that the volume is a CSI volume.kubectl describe pv default-pvc-2-a8486 Name: default-pvc-2-a8486 Labels: <none> Annotations: pv.kubernetes.io/provisioned-by: csi.trident.netapp.io volume.beta.kubernetes.io/storage-class: standard Finalizers: [kubernetes.io/pv-protection] StorageClass: standard Status: Bound Claim: default/pvc-2 Reclaim Policy: Delete Access Modes: RWO VolumeMode: Filesystem Capacity: 1073741824 Node Affinity: <none> Message: Source: Type: CSI (a Container Storage Interface (CSI) volume source) Driver: csi.trident.netapp.io VolumeHandle: default-pvc-2-a8486 ReadOnly: false VolumeAttributes: backendUUID=c5a6f6a4-b052-423b-80d4-8fb491a14a22 internalName=trid_1907_alpha_default_pvc_2_a8486 name=default-pvc-2-a8486 protocol=file Events: <none>In this manner, you can upgrade volumes of the NFS/iSCSI type that were created by Astra Trident to the CSI type, on a per-volume basis.
