Troubleshoot Upgrade Health Checker
Learn how to troubleshoot common Upgrade Health Checker issues and resolve errors that can block ONTAP upgrade planning.
Troubleshoot issues
Issue: Authentication or credential errors
Symptoms:
Failed to fetch cluster details for <cluster-ip> Error connecting to ONTAP cluster: 401 Unauthorized Missing cluster credentials
These errors indicate that Upgrade Health Checker is unable to authenticate with the ONTAP cluster using the provided credentials. This can be caused by an incorrect username or password, insufficient permissions for the user account, or an account that is locked or disabled.
Solutions:
Verify that the username and password are correct
Ensure the user has sufficient ONTAP REST API permissions
Check if the account is locked or disabled
./uhc --test-connectivity cluster
Issue: Auto-update fails
Symptoms:
Auto-update failed: ... Failed to download update
These errors indicate that Upgrade Health Checker is unable to connect to the internet to check for or download updates. This can be caused by network connectivity issues, firewall rules blocking access, or proxy settings that are not configured correctly.
Solutions:
Check internet connectivity:
./uhc --test-connectivity autoupdate
Check disk space (requires 1 GB):
df -h <location of uhc>
Issue: Binary takes a long time to start
Cause: The binary is self-contained and needs to unpack itself before executing.
Expected Behavior: First execution might take a few seconds to load. This is normal.
Issue: "Permission denied" or "Cannot execute binary" on /tmp
Symptoms:
[Errno 13] Permission denied OSError: [Errno 13] Permission denied: '/tmp/_MEI...' Cannot execute binary file
This error might occur when the tool is unable to execute files in the /tmp directory, which is used for extracting and running the tool's components. This can be caused by restrictive permissions on the /tmp directory or security policies that prevent execution from this location.
Solutions:
Check if
/tmphasnoexecenabled:
mount | grep /tmp # If you see noexec in the output, this is the issue.
# Temporary fix sudo mount -o remount,exec /tmp # Permanent fix - edit /etc/fstab # Change "noexec" to "exec" for /tmp mount point
mkdir -p /custom-tmp-path # This only needs to be done one time. TMPDIR=/custom-tmp-path ./uhc # The TMPDIR prefix has to be added every time.
The custom path must first exist for this workaround to work. If it doesn’t already exist, it is not created and falls back to using /tmp.
Issue: Connection timeout
Symptoms:
Connection timeout Request timeout
Solutions:
Check network connectivity to the cluster
Verify that no firewall is blocking HTTPS (443) traffic
Check the cluster is responsive and not under a heavy load
Issue: Insufficient disk space
Symptoms:
Not enough disk space available OSError: [Errno 28] No space left on device
Solutions:
Check disk space:
df -h /tmp df -h .
Clean old runs:
# Remove old run directories rm -rf runs/<old_run_directories>
Clean temporary files:
# Remove temporary files rm -rf /tmp/_MEI*
Issue: Invalid runs path
Symptoms:
Invalid basepath_runs: <error> RUNS path is not set Cannot create tarball: basepath_runs '<path>' does not exist
Solutions:
Ensure that the runs output directory exists and is writable
Specify a valid path via CLI:
--runs-path /valid/path -
Configure in config.yaml:
APP.RUNS_PATH: "/valid/path"
Issue: Invalid target ONTAP version
Symptoms:
Invalid ONTAP version: '<version>' does not exist Invalid ONTAP version: '<version>' is not a recognized ONTAP version Downgrade is not supported. Target version must be greater than or equal to the current version.
Solutions:
Verify the target version string format (e.g. "9.16.1")
Ensure that the target version is newer than or equal to the current cluster version
Use "current" to keep the existing ONTAP version:
--target-ontap-version=current
Issue: Signature verification fails
Symptoms:
Signature verification failed Invalid code signature
Cause: Downloaded update file might be corrupted or have been tampered with.
Solution:
Manual update - download from the NetApp support site
Verify signature manually:
openssl dgst -sha256 -verify UHC-Linux-public.pub -signature uhc.sig uhc
Issue: Telemetry upload failure
Symptoms:
body.7z upload failed Telemetry endpoint is not reachable
Solutions:
Check connectivity to the telemetry endpoint:
./uhc --test-connectivity telemetry
Issue: "UPDATE IN PROGRESS" lock file
Symptoms:
UPDATE IN PROGRESS
Another instance of UHC auto-update is currently running.
Please wait for the update to complete before running again.
Cause: Lock file exists from previous update process.
Solutions:
Wait: Update typically completes in 1-2 minutes.
Check, if stale: (automatic cleanup after 1 hour):
ls -la uhc_update.lock # If older than 1 hour, it will be auto-cleaned
rm uhc_update.lock
