Upgrade Health Checker
Input parameters for Upgrade Health Checker
Contributors netapp-ivanad netapp-yvonneo
You can learn more about the input parameters for Upgrade Health Checker and how to provide them through CLI arguments, configuration files, or interactive prompts to assist you with generating an upgrade report for your ONTAP cluster.
Input methods priority
Upgrade Health Checker provides several input options for all parameters. Its priority order for accepting inputs is:
  1. CLI arguments (highest priority)
  2. Configuration file (config.yaml)
  3. Interactive prompts (lowest priority)
When a parameter is provided through multiple methods, the tool will use the value from the highest priority source.
Input parameters
Cluster IP
The --cluster-ip parameter specifies the IP address or hostname of the ONTAP cluster to connect to.
The priority order for providing this parameter is:
  1. CLI argument: --cluster-ip
  2. Config file: CLUSTER.IP
  • CLI argument:
    ./uhc --cluster-ip 192.168.1.100
  • Config.yaml:
    CLUSTER:
      IP: "192.168.1.100"
  • Interactive mode (if not provided above):
    Tool will prompt: Enter cluster IP address:
Cluster username
The --cluster-username parameter specifies the username for authenticating with the ONTAP cluster.
  1. CLI argument: --cluster-username
  2. Config file: CLUSTER.USERNAME
  • CLI argument:
    ./uhc --cluster-username admin
  • Config.yaml:
    CLUSTER:
      USERNAME: "admin"
    Tool will prompt: Enter cluster username:
Cluster password
The --cluster-password parameter specifies the password for authenticating with the ONTAP cluster.
  1. CLI argument: --cluster-password
  2. Config file: CLUSTER.PASSWORD
  3. Interactive prompt (secure input)
  • CLI argument (not recommended for security):
    ./uhc --cluster-password mypassword
  • Config.yaml (ensure file permissions are restricted):
    CLUSTER:
      PASSWORD: "mypassword"
  • Interactive mode (recommended - password hidden):
    Tool will prompt: Enter cluster password:
Target ONTAP version
The --target-ontap-version parameter specifies the ONTAP version you want to upgrade to for analysis. Use "current" to keep the existing cluster ONTAP version.
  1. CLI argument: --target-ontap-version
  2. Config file: CLUSTER.TARGET_ONTAP_VERSION
  3. Interactive selection menu
  • CLI argument:
    Updated version of ONTAP: ./uhc --target-ontap-version 9.15.1
    Keep current version of ONTAP: ./uhc --target-ontap-version current
  • Config.yaml:
    CLUSTER:
      TARGET_ONTAP_VERSION: "9.15.1"
    Tool will display available versions and prompt for selection
Accept EULA
The --accept-eula parameter specifies whether to accept the End User License Agreement. Must be set to true to proceed.
  1. CLI argument: --accept-eula
  2. Config file: CLUSTER.ACCEPT_EULA
  • CLI argument:
    ./uhc --accept-eula true
  • Config.yaml:
    CLUSTER:
      ACCEPT_EULA: true
    Tool will display EULA and prompt for acceptance
Configuration file path
The --config-path parameter specifies the path to a custom configuration YAML file.
  1. CLI argument: --config-path
  2. Default: config.yaml
  • CLI argument:
    ./uhc --config-path /path/to/custom_config.yaml
  • Default (if not provided):
    Tool will look for config.yaml in the current directory
Run output path
The --runs-path parameter specifies a custom directory for storing run outputs and reports.
  1. CLI argument: --runs-path
  2. Config file: APP.RUNS_PATH
  3. Default: ./runs
  • CLI argument:
    ./uhc --runs-path /custom/output/path
  • Config.yaml:
    APP:
      RUNS_PATH: "/custom/output/path"
    Tool will use ./runs directory
Skip compatibility check
The --skip-compatibility-check parameter bypasses hardware compatibility checks and uses the specified version of ONTAP you want to upgrade to.
Caution Only use this option if you are certain the target ONTAP version is compatible with your hardware.
  1. CLI argument: --skip-compatibility-check
  2. Config file: CLUSTER.SKIP_COMPATIBILITY_CHECK
  3. Default: false
  • CLI argument:
    ./uhc --skip-compatibility-check true
  • Config.yaml:
    CLUSTER:
      SKIP_COMPATIBILITY_CHECK: true
Dashboard
The --dashboard parameter regenerates the dashboard from existing runs at <runs>/dashboard/index.html without contacting a cluster. You use it to refresh the fleet view outside of a normal run. The dashboard provides a high-level overview of the health status of all the clusters that have been assessed recently, allowing you to easily monitor and compare the upgrade readiness of multiple clusters in one place. You can open the dashboard in a web browser to view the health status, potential blockers, and risks for each cluster at a glance.
  • CLI argument: --dashboard
  • CLI argument:
    ./uhc --dashboard
    ./uhc --dashboard --runs-path /custom/output
    ./uhc --dashboard --config-path /path/to/custom_config.yaml
Disable telemetry
To disable telemetry, add the following to your config.yaml file:
TELEMETRY:
  ENABLED: false
Disable automatic updates
To disable automatic updates for Upgrade Health Checker, add the following to your config.yaml file:
AUTO_UPDATE:
  ENABLED: false
Examples using each input method
Combined CLI arguments
./uhc \
  --cluster-ip 192.168.1.100 \
  --cluster-username admin \
  --cluster-password mypassword \
  --target-ontap-version 9.15.1 \
  --accept-eula true \
  --config-path /path/to/custom_config.yaml \
  --runs-path /custom/output \
  --skip-compatibility-check false
Config.yaml file
CLUSTER:
  IP: "192.168.1.100"
  USERNAME: "admin"
  ACCEPT_EULA: true
  SKIP_COMPATIBILITY_CHECK: false
APP:
  RUNS_PATH: "/custom/output"
Interactive mode
To prompt all required input parameters interactively, run Upgrade Health Checker without arguments:
./uhc
Additional commands
These commands provide some additional capabilities beyond the full run of the tool:
  • Display help
    ./uhc --help
  • Display version
    ./uhc --version
  • Test cluster connectivity
    ./uhc --test-connectivity cluster
  • Test telemetry connectivity
    ./uhc --test-connectivity telemetry
  • Test auto-update connectivity
    ./uhc --test-connectivity autoupdate
  • Run all tests
    ./uhc --test all
