Application Entitlement Workflow for AVD
Overview
In a Azure Virtual Desktop (AVD) environment, application access is managed by app group membership.
This workflow only applies to AVD deployments. For RDS application entitlement documentation, please see Application Entitlement Workflow for RDS |
AVD is a well documented service and there are many public resources for information. VDS does not superseed the standard way that AVD operates. Rather, this article is designed to illustrate how VDS approaches the standard concept found across all AVD deployments. |
Reviewing the VDS Logical Hierarchy Overview article may be useful before or while reviewing this article. |
The End User View
In Azure Virtual Desktop, each end user is assigned access to RemoteApp(s) and/or Desktop(s) by their AVD administrator. This is accomplished via App Group assignment in VDS.
RemoteApp refers to an application that runs remotely on the session host but is presented on the local device without the desktop context. Commonly referred to as a "streaming app", these application look like a local application on the local device but run in the security context, and on the storage and compute layer of the session host.
Desktop refers to the full Windows experience running on the session host and presented on the local device, typically in a full screen window. Commonly referred to as "remote desktop", this desktop itself will contain any applications installed on that session host which can be launched by the user from within the desktop session window.
At login, the end user is presented with the resources assigned to them by their administrator. Below is an example of the view an end user may see when logging in with their AVD client. This is a more complex example, often an end user will only have a dingle desktop or RemoteApp assigned to them. The end user can double click on any of these resources to launch that application/desktop.
In this more complex example, this user has access to two different desktop sessions and 4 different streaming applications:
Available Desktops
Nvidia GPU Desktop
Shared AVD Pool Desktop
Operation 2 Pool Desktop
Available RemoteApps
AutoCAD 2021
Revit 2021
Microsoft Edge
Notepad
Behind the scenes these applications and desktops are hosted across a variety of session hosts, AVD workspaces and could even be hosted in different Azure regions.
Here is a diagram illustrating where each of these resources are hosted and how they got assigned to this end user.
As shown above, the various resources available to this end user are hosted in different session hosts, in different host pools, and potentially managed by different IT organizations in different AVD Workspaces. While not showing in this example, these resources could also be hosted in different Azure regions and/or subscriptions using the VDS Sites feature.
Providing Desktop Access
By default every host pool starts with a single app group, used to assign access to the Windows desktop experience. All applications installed on these session hosts will be accessible to the end users assigned to this app group.
Navigate to the Workspaces > AVD > Host Pool > App Groups page and click on the App group for the "Desktop" resource.
Once inside the App Group, click Edit
From the edit dialog, you can add or remove users to this App Group by User and/or by Groups.
Providing RemoteApp Access
In order to provision access to RemoteApps, a new app group needs to be created within the host pool. Once created, the appropriate apps need to be assigned to this app group.
Any applications on these sessions hosts will already be available to any users assigned to this host pool’s "Desktop" AppGroup. It is not necessary to also provision access via a RemoteApp app group simply to provide access to apps. A RemoteApp app group is only necessary to enable access to apps that run as-if on the local device as a streaming app. |
Create a New App Group
Navigate to the Workspaces > AVD > Host Pool > App Groups page and click on the + Add App Group button
Enter the Name, Workspace and Friendly Name for this app group. Select the users and/or groups that should be assigned and click Save
Add Applications to the App Group
Navigate to the Workspaces > AVD > Host Pool > App Groups page and click on the App group for the "RemoteApp" resource.
Scroll down to the "Remote Apps" section. This section may take a moment to populate as VDS is directly querying the session hosts to show available apps for streaming.
Search and select any apps that the users in this app groups should have access to as a RemoteApp resource.
