Resource Optimization
Workload scheduling
Workload Scheduling is a feature that can schedule the time window in which the environment is active.
Workload scheduling can be set to "Always On", "Always Off" or "Scheduled". When set to "Scheduled" the on and off times can be set as granularly as a different time window for each day of the week.
Workload schedule1
When scheduled to be off, either via "Always Off" or "Scheduled", all tenant virtual machines will shut down. Platform servers (such as CWMGR1) will remain active to facilitate functionality such as wake on demand.
Workload Schedule works in conjunction with other resource optimization features including Live Scaling and Wake on Demand.
Wake on demand
Wake on Demand (WoD) is patent-pending technology that can wake the appropriate VM resources for an end user in order to facilitate unattended access 24/7, even when resources are scheduled to be inactive.
WoD for Remote Desktop Services
In RDS, the VDS Windows Client has built-in Wake on Demand integration and can wake the appropriate resources without any additional end-user actions. They simply need to initiate their normal login and the client will notify them of a short delay which the VM(s) are activated. This client (and thus this automate wake on demand functionality) is only available when connecting from a Windows device to an RDS environment.
Similar Functionality is built into the VDS Web client for RDS deployments. The VDS Web Client is found at: https://login.cloudworkspace.com
Wake on Demand functionality is not built into the Microsoft RD client (for Windows or any other platform) nor any other 3rd party RD clients.
Wake on demand for Azure Virtual Desktop
In AVD, the only clients that can be used to connect are Microsoft provided and thus do not contain the Wake on Demand functionality.
VDS does include a self-service Wake on Demand function for AVD via the VDS Web Client. The web client can be used to wake the appropriate resources, then the connection can be initiated via the standard AVD client.
To wake VM resources in AVD:
  1. Connect to the VDS Web Client at https://login.cloudworkspace.com
  2. Login with the user AVD credentials
    • A warning message will prompt "You have Microsoft’s AVD services available. Click HERE to view the status and start offline Host Pools."
  3. After clicking "HERE" you’ll see a list of available Host Pools along with a link to "Click to Start" link under the status column
    Wake on Demand h5 1
  4. Click to Start the link and wait 1-5 minutes for the status to change to "Online" and show a green status icon
  5. Connect to AVD using your normal process
Live Scaling
Live Scaling works in conjunction with Workload Scheduling by managing the number of online session hosts during the scheduled active time as configured in Workload Scheduling. When scheduled to be offline, Live Scaling won’t control session host availability. Live scaling only impacts Shared Users and Shared Servers in RDS and AVD environments, VDI Users and VDI VMs are excluded from these calculations. All other VM types are unaffected.
Note The AVD load balancer type setting interacts with this configuration, so care should be taken in choosing that setting as well. Cost savings are maximized with a depth-first type while end user performance is maximized with a breadth-first type.
Enabling Live Scaling with no options checked, the automation engine will automatically select values for the Number of Extra Powered on Servers, Shared Users Per Server, and Max Shared Users Per Server.
  • The Number of Extra Powered on Servers defaults to 0, meaning 1 server will run 24/7.
  • The Shared Users Per Server defaults to the number users in the company divided by the number of servers.
  • The Max Shared Users Per Server defaults to infinite.
Live Scaling turns the servers on as users log on and turns them off as users log off.
Powering an additional server is automatically triggered once the total active users reaches the number of Shared Users per Server multiplied by the total number of Powered On Servers.
e.g. With 5 Shared Users per Server set (this is the default # we’ll use for all examples in this article) and 2 servers running, a 3rd server won’t be powered up until server 1 & 2 both have 5 or more active users. Until that 3rd server is available, new connections will be load balanced all available servers. In RDS and AVD Breadth mode, Load balancing sends users to the server with the fewest active users (like water flowing to the lowest point). In AVD Depth mode, Load balancing sends users to servers in a sequential order, incrementing when the Max Shared Users number is reached.
Live Scaling will also turn off servers to save costs. When a server has 0 active users, and another server has available capacity below Shared Users per Server the empty server will be powered down.
Powering on the next server can take a few minutes. In certain situations the speed of logins can outpace the availability of new servers. For example, if 15 people login in 5 minutes they’ll all land on the first server (or be denied a session) while a 2nd and 3rd power up. There are two strategies that can be used to mitigate overloading a single server in this scenario:
  1. Enable Number of Extra Powered on Servers so that the additional server(s) will be on and available to accept connections and allow time for the platform to spin up additional servers.
    1. When activated, the number is added to the calculated need. For example, if set to 1 extra server (and with 6 users connected) two servers would be active because of the users count, plus a 3rd due to the Extra Powered on Servers setting.
  2. Enable Max Shared Users Per Server to place a hard limit on the number of users allowed per server. New connections that would exceed this limit will be refused, the end user will get an error message and need to try again in a couple minutes once the additional server is available. If set, this number also defines the depth of AVD Shared servers.
    1. Assuming the delta between Shared Users Per Server and Max Shared Users Per Server is appropriate, the new servers should become available before the max is reached in all but the most extreme situations (unusually large login storms).
VM resource scaling
VM Resource scaling is a optional feature that can change the size and quantity of session host VMs in an environment.
When activated, VDS will calculate the appropriate size and quantity of session host VMs based on your selected criteria. These options include: Active Users, Named Users, Server Load, and Fixed.
VMResource2
The size of the VMs is contained with the family of VMs selected in the UI which can be changed by dropdown. (e.g. Standard Dv3 Family in Azure)
VMResource1
Scaling based on users
Note The function below behaves the same for either "Active Users" or "User Count". User Count is a simply count of all users activated with a VDS desktop. Active Users is a calculated variable based on the previous 2 weeks of user session data.
When calculating based on users, the size (and quantity) of the session host VMs is calculated based on the defined RAM and CPU requirements. The administrator can define the GB of RAM, and number of vCPU cores per user along with additional non-variable resources.
In the screenshot below, each user is allocated 2GB RAM and 1/2 of a vCPU core. Additionally, the server starts with 2 vCPU cores and 8GB RAM.
VMResource3
Additionally, the administrator can define the maximum size a VM can reach. When reached, environments will scale horizontally by adding additional VM session hosts.
In the screenshot below, each VM is limited to 32GB Ram and 8vCPU cores.
VMResource4
With all of these variables defined, VDS can calculate the appropriate size and quantity of session host VMs, greatly simplifying the process of maintaining appropriate resource allotment, even as users are added and removed.
Scaling based on server load
When calculating based on server load, the size (and quantity) of session host VMs is calculated based on the average CPU/RAM utilization rates as observed by VDS over the previous 2-week period.
When the maximum threshold is exceeded, VDS will increase the size or increment the quantity to bring average usage back within range.
Like user based scaling, the VM Family and the maximum VM size can be defined.
VMResource6
Other active resources
Workload Scheduling does not control the platform servers such as CWMGR1 as they are needed to trigger the Wake on Demand functionality and facilitate other platform tasks and should run 24/7 for normal environmental operation.
Additional saving can be achieved by deactivating the entire environment but is only recommended for non-production environments. This is a manual action that can be performed in the Deployments section of VDS. Returning the environment to a normal status also requires a manual step on the same page.
Stop Deployment
Start deployment
