English
WVD and VDS prerequisites
Contributors tvanroo Download PDF of this page
WVD and VDS requirements and notes
This document describes the required elements for deploying Windows Virtual Desktop (WVD) using NetApp Virtual Desktop Service (VDS). The “Quick Checklist” provides a brief list of required components and pre-deployment steps to take to ensure an efficient deployment. The rest of the guide provides greater detail for each element, depending on the configuration choices that are made.
Quick checklist
Azure requirements
  • Azure Tenant with Azure AD instance (can be Microsoft 365 instance)
  • Azure Subscription
  • Available Azure Quota for Azure virtual machines
  • Azure Admin Account with Global Admin and Subscription Ownership Roles
  • Domain admin account with 'Enterprise Admin' role for AD Connect setup
Pre-deployment information
  • Determine total number of users
  • Determine Azure Region
  • Determine Active Directory Type
  • Determine Storage Type
  • Identify session host VM image or requirements
  • Assess existing Azure and on-premises networking configuration
VDS deployment detailed requirements
End user connection requirements
The following Remote Desktop clients support Windows Virtual Desktop:
  • Windows Desktop
  • Web
  • macOS
  • iOS
  • IGEL Think Client (Linux)
  • Android (Preview)
Windows Virtual Desktop does not support the RemoteApp and Desktop Connections (RADC) client or the Remote Desktop Connection (MSTSC) client.
Windows Virtual Desktop does not currently support the Remote Desktop client from the Windows Store. Support for this client will be added in a future release.
The Remote Desktop clients must have access to the following URLs:
Address Outbound TCP Port Purpose Client(s)
*.wvd.microsoft.com
443
Service traffic
All
*.servicebus.windows.net 443 Troubleshooting data
All
go.microsoft.com
443
Microsoft FWLinks
All
aka.ms
443
Microsoft URL shortener
All
docs.microsoft.com
443
Documentation
All
privacy.microsoft.com
443
Privacy statement
All
query.prod.cms.rt.microsoft.com
443
Opening these URLs is essential for a reliable client experience. Blocking access to these URLs is unsupported and will affect service functionality. These URLs only correspond to the client sites and resources, and do not include URLs for other services like Azure Active Directory.
VDS setup wizard starting point
The VDS setup wizard can handle much of the prerequisite setup required for a successful WVD deployment. The setup wizard (https://cwasetup.cloudworkspace.com) either creates or uses the following components.
Azure tenant
Required: An Azure tenant and Azure Active Directory
WVD activation in Azure is a tenant-wide setting. VDS supports running one WVD instance per tenant.
Azure subscription
Required: An Azure subscription (note the subscription ID that you want to use)
All the deployed Azure resources should be setup in one dedicated subscription. This makes cost tracking for WVD much easier and simplifies the deployment process.
NOTE: Azure free trials are not supported as they do not have enough credits to deploy a functional WVD deployment.
Azure core quota
Enough quota for the VM families you will use - specifically at least 10 cores of the Ds v3 family for the initial platform deployment (as few as 2 cores can be used, but 10 covers every initial deployment possibility).
Azure admin account
Required: An Azure global administrator account.
The VDS setup wizard requests that the Azure admin grant delegated permissions to the VDS service principal and install the VDS Azure Enterprise application. The admin must have the following Azure roles assigned:
  • Global Administrator on the tenant
  • Owner role on the subscription
VM image
Required: An Azure image that supports multi-session Windows 10.
The Azure Marketplace provides the most recent versions of their base Windows 10 image and all Azure subscriptions have access to those automatically. If you want to use a different image or a custom image, want the VDS team to provide advice about creating or modifying other images or have general questions about Azure images let us know and we can schedule a conversation.
Active Directory
WVD requires that the user identity be a part of Azure AD and that the VMs are joined to an Active Directory domain that is synced with that same Azure AD instance. VMs cannot be attached directly to the Azure AD instance so a domain controller needs to be configured and in-sync with Azure AD.
These supported options include:
  • The automated build of an Active Directory instance within the subscription. The AD instance is typically created by VDS on the VDS control VM (CWMGR1) for Windows Virtual Desktop deployments that use this option. AD Connect must be setup and configured to sync with Azure AD as part of the setup process.
    AD Options New
  • Integration into an existing Active Directory domain that is accessible from the Azure subscription (typically via Azure VPN or Express Route) and has its user list synced with Azure AD using AD Connect or a 3rd party product.
    AD Options Existing
Storage layer
In WVD the storage strategy is designed so that no persistent user/company data resides on the WVD session VMs. Persistent data for user profiles, user files and folders, and corporate/application data are hosted on one or more data volume(s) hosted on an independent data layer.
FSLogix is a profile containerization technology that solves many user profile issues (like data sprawl and slow logins) by mounting a user profile container (VHD or VHDX format) to the session host at session initialization.
Due to this architecture a data storage function is required. This function must be able to handle the data transfer required each morning/afternoon when a significant portion of the users login/logoff at the same time. Even moderately sized environments can have significant data transfer requirements. The disk performance of the data storage layer is one of the primary end user performance variables and special care must be taken to appropriately size the performance of this storage, not just the amount of storage. Generally, the storage layer should be sized to support 5-15 IOPS per user.
The VDS Setup wizard supports the following configurations:
  • Setup and configuration of Azure NetApp Files (ANF) (Recommended). ANF standard service level supports up to 150 users, while environments of 150-500 users ANF Premium is recommended. For 500+ users ANF Ultra is recommended.
    Storage Layer 1
  • Setup and configuration of a File Server VM
    Storage Layer 3
Networking
Required: An inventory of all existing network subnets including any subnets visible to the Azure subscription via an Azure Express Route or VPN. The deployment needs to avoid overlapping subnets.
The VDS setup wizard allows you to define the network scope in case there is a range that is required, or must be avoided, as part of the planned integration with existing networks.
Determine an IP range to user during your deployment. Per Azure best practices, only IP addresses in a private range are supported.
Supported choices include the following but default to a /20 range:
  • 192.168.0.0 through 192.168.255.255
  • 172.16.0.0 through 172.31.255.255
  • 10.0.0.0 through 10.255.255.255
CWMGR1
Some of the unique capabilities of VDS such as the cost saving Workload Scheduling and Live Scaling functionality require an administrative presence within the tenant and subscription. Therefore, an administrative VM called CWMGR1 is deployed as part of the VDS setup wizard automation. In addition to VDS automation tasks this VM also holds VDS configuration in a SQL express database, local log files and an advanced configuration utility called DCConfig.
Depending on the selections made in the VDS setup wizard, this VM can be used to host additional functionality including:
  • An RDS gateway (only used in RDS deployments)
  • An HTML 5 gateway (only used in RDS deployments)
  • An RDS license server (only used in RDS deployments)
  • A Domain Controller (if chosen)
Decision tree in the Deployment Wizard
As part of the initial deployment a series of questions are answered to customize the settings for the new environment. Below is an outline of the major decisions to be made.
Azure region
Decide which Azure region or regions will host your WVD Virtual Machines. Note that Azure NetApp Files and certain VM families (GPU enabled VMs, for example) have a defined Azure region support list while WVD is available in most regions.
Active Directory type
Decide which Active Directory type you want to use:
  • Existing on-prem Active Directory
  • Refer to the WVD VDS Components and Permissions document for an explanation of the required permissions and components in both Azure and the local Active Directory environment
  • New Azure subscription based Active Directory instance
  • Azure Active Directory Domain Services
Data Storage
Decide where the data for user profiles, individual files, and corporate shares will be placed. Choices include:
  • Azure NetApp Files
  • Azure Files
  • Traditional File Server (Azure VM with Managed Disk)
NetApp VDS Deployment Requirements for Existing Components
NetApp VDS Deployment with Existing Active Directory Domain Controllers
This configuration type extends an existing Active Directory domain to support the WVD instance. In this case VDS deploys a limited set of components into the domain to support automated provisioning and management tasks for the WVD components.
This configuration requires:
  • An existing Active Directory domain controller that can be accessed by VMs on the Azure VNet, typically via either Azure VPN or Express Route OR a domain controller that has been created in Azure.
  • Addition of VDS components and permissions required for VDS management of WVD host pools and data volumes as they are joined to the domain. The WVD VDS Components and Permissions guide defines the required components and permissions and the deployment process requires a Domain user with domain privileges to execute the script that will create the needed elements.
  • Note that the VDS deployment creates a VNet by default for VDS created VMs. The VNet can be either peered with existing Azure network VNets or the CWMGR1 VM can be moved to an existing VNet with the required subnets pre-defined.
Credentials and domain preparation tool
Administrators must provide a Domain Administrator credential at some point in the deployment process. A temporary Domain Administrator credential can be created, used and deleted later (once the deployment process completes).
Alternatively, customers who require assistance in building out the pre-requisites can leverage the Domain Preparation Tool.
NetApp VDS deployment with existing file system
VDS creates Windows shares that allow user profile, personal folders, and corporate data to be accessed from WVD session VMs. VDS will deploy either the File Server or Azure NetApp File options by default, but if you have an existing file storage component VDS can point the shares to that component once the VDS deployment is complete.
The requirements for using and existing storage component:
  • The component must support SMB v3
  • The component must be joined to the same Active Directory domain as the WVD session hosts
  • The component must be able to expose a UNC path for use in the VDS configuration – one path can be used for all three shares or separate paths may be specified for each. Note that VDS will set user level permissions on these shares so refer to the VDS WVD Components and Permissions document to ensure the appropriate permissions have been granted to the VDS Automation Services.
NetApp VDS deployment with existing Azure AD Domain Services
This configuration requires a process to identify the attributes of the existing Azure Active Directory Domain services instance. Contact your account manager to request a deployment of this type.
NetApp VDS Deployment with Existing WVD deployment
This configuration type assumes that the necessary Azure VNet, Active Directory, and WVD components already exist. The VDS deployment is performed in the same manner as the “NetApp VDS Deployment with Existing AD” configuration, but adds the following requirements:
  • RD Owner role to the WVD Tenant needs to be granted to the VDS Enterprise Applications in the Azure
  • WVD Host Pool and WVD Host Pool VMs need to be imported into VDS using the VDS Import function in the VDS Web App. This process collects the WVD host pool and session VM metadata and stores in it VDS so that these elements can be managed by VDS
  • WVD User data needs to be imported into the VDS User section using the CRA tool. This process inserts metadata about each user into the VDS control plane so their WVD App Group membership and session information can be managed by VDS
APPENDIX A: VDS control plane URLs and IP addresses
VDS components in the Azure subscription communicate with the VDS global control plane components such as the the VDS Web Application and the VDS API endpoints. For access, the following base URI addresses need to be whitelisted for bi-directional access on port 443:
If your access control device can only white list by IP address, the following list of IP addresses should be whitelisted. Note that VDS uses the Azure Traffic Manager service, so this list may change over time:
13.67.190.243
13.67.215.62
13.89.50.122
13.67.227.115
13.67.227.230
13.67.227.227
23.99.136.91
40.122.119.157
40.78.132.166
40.78.129.17
40.122.52.167
40.70.147.2
40.86.99.202
13.68.19.178
13.68.114.184
137.116.69.208
13.68.18.80
13.68.114.115
13.68.114.136
40.70.63.81
52.171.218.239
52.171.223.92
52.171.217.31
52.171.216.93
52.171.220.134
92.242.140.21
APPENDIX B: Microsoft WVD requirements
This Microsoft WVD Requirements section is a summary of WVD requirements from Microsoft. Complete and current WVD requirements can be found here:
Windows Virtual Desktop session host licensing
Windows Virtual Desktop supports the following operating systems, so make sure you have the appropriate licenses for your users based on the desktop and apps you plan to deploy:
OS Required license
Windows 10 Enterprise multi-session or Windows 10 Enterprise
Microsoft 365 E3, E5, A3, A5, F3, Business Premium
Windows E3, E5, A3, A5
Windows 7 Enterprise
Windows Server 2012 R2, 2016, 2019
RDS Client Access License (CAL) with Software Assurance
URL Access for WVD machines
The Azure virtual machines you create for Windows Virtual Desktop must have access to the following URLs:
Address Outbound TCP Port Purpose Service Tag
*.wvd.microsoft.com
443
Service traffic
WindowsVirtualDesktop
mrsglobalsteus2prod.blob.core.windows.net
443
Agent and SXS stack updates
AzureCloud
*.core.windows.net
443
Agent traffic
AzureCloud
443
Agent traffic
AzureCloud
prod.warmpath.msftcloudes.com
443
Agent traffic
AzureCloud
catalogartifact.azureedge.net
443
Azure Marketplace
AzureCloud
kms.core.windows.net
1688
Windows activation
Internet
wvdportalstorageblob.blob.core.windows.net
443
Azure portal support
AzureCloud
The following table lists optional URLs that your Azure virtual machines can have access to:
*.microsoftonline.com
443
Authentication to MS Online Services
None
*.events.data.microsoft.com
443
Telemetry Service
None
www.msftconnecttest.com
443
Detects if the OS is connected to the internet
None
*.prod.do.dsp.mp.microsoft.com
443
Windows Update
None
login.windows.net
443
Login to MS Online Services, Office 365
None
*.sfx.ms
443
Updates for OneDrive client software
None
*.digicert.com
443
Certificate revocation check
None
Optimal performance factors
For optimal performance, make sure your network meets the following requirements:
  • Round-trip (RTT) latency from the client’s network to the Azure region where host pools have been deployed should be less than 150ms.
  • Network traffic may flow outside country/region borders when VMs that host desktops and apps connect to the management service.
  • To optimize for network performance, we recommend that the session host’s VMs are collocated in the same Azure region as the management service.
Supported virtual machine OS images
Windows Virtual Desktop supports the following x64 operating system images:
  • Windows 10 Enterprise multi-session, version 1809 or later
  • Windows 10 Enterprise, version 1809 or later
  • Windows 7 Enterprise
  • Windows Server 2019
  • Windows Server 2016
  • Windows Server 2012 R2
Windows Virtual Desktop does not support x86 (32-bit), Windows 10 Enterprise N, or Windows 10 Enterprise KN operating system images. Windows 7 also does not support any VHD or VHDX-based profile solutions hosted on managed Azure Storage due to a sector size limitation.
Available automation and deployment options depend on which OS and version you choose, as shown in the following table:
Operating System Azure Image Gallery Manual VM Deployment ARM Template Integration Provision Host Pools on Azure Marketplace
Windows 10 multi-session, version 1903
Yes
Yes
Yes
Yes
Windows 10 multi-session, version 1809
Yes
Yes
No
No
Windows 10 Enterprise, version 1903
Yes
Yes
Yes
Yes
Yes
Yes
No
No
Yes
Yes
No
No
Windows Server 2019
Yes
Yes
No
No
Windows Server 2016
Yes
Yes
Yes
Yes
Yes
Yes
No
No
